Embedded and Microcontrollers blog White Paper: Multi-core microcontroller design with Cortex-M processors and CoreSight SoC
  • White Paper
  • Cortex-M
  • CoreSight
Ping Zuo 左平
Ping Zuo 左平
April 24, 2014
by Joseph Yiu & Ian Johnson
Abstract
While the majority of Cortex-M processor-based microcontrollers are single core designs, some new microcontrollers with multiple Cortex-M processors are also available. As multi-core designs are increasing in popularity and complexity, the methodologies of designing multi-core Cortex-M systems are becoming more critical.  This paper introduces typical system level designs for multi-core Cortex-M microcontrollers and some of the various factors that need to be considered when designing the memory system, together with low power support and additional hardware to allow multi-core systems to work effectively.  This paper also covers example debug subsystems for multi-core designs, the features typically needed in multiple core debug systems, such as debug event communication; and the way in which the Processor Integration Layer in ARM’ CoreSight™ SoC debug and trace technology supports the required debug functionality.
Multi-core microcontroller design with Cortex-M processors and Cor.pdf
  • Diya Soubra
    Diya Soubra over 9 years ago
    link to registration page
    https://armtechcon.tech.ubm.com/2015/?
  • Diya Soubra
    For those interested in multicore designs for Cortex-M processors please join us at TechCon 2015 for a panel session with industry experts titled:
    "Simplifying software development for SoCs containing multiple Cortex-M based processors"
    Date:  Thursday, November 12
    Time:  4:30pm - 5:20pm
    Format: 50-Minute Panel
    Track: Embedded
    Pass Type: Conference Pass
    ARM TechCon 2015 Schedule | Simplifying Software Development for Socs Containing Multiple Cortex-M Based Processors
    Abstract
    In IoT and Wearable designs it can sometimes be better to use SoCs containing multiple Cortex-M processors rather than a single higher performance core. Such devices already exist and are successfully used, however sometimes a more unified software environment would make software development easier ideally a developer should be able to write higher-level code as if on a single processor.
    With experts from MCU suppliers, RTOS and tool vendors, and from the developer community, this panel looks at the needs of multi-processor embedded software environments and what the embedded industry could do to make this a true success.
    The audience should gain:
    -an understanding of when multiple Cortex-M processor systems offer advantages
    -knowledge of the industry status in solving the software challenge
    -knowledge of where to find existing solutions.
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
  • Adapting Kubernetes for high-performance IoT Edge deployments
    Alexandre Peixoto Ferreira
    In this blog post, we address heterogeneity in IoT edge deployments using Kubernetes.
    • August 21, 2024
