Embedded and Microcontrollers blog The SAM L22 is an ARM Cortex-M0+ MCU with a segment LCD controller
  • atmel
  • Arm
  • Embedded
  • l22
  • Cortex-M0+
  • cortex_m0+
  • sam
Artie Beavis
Artie Beavis
August 18, 2015
Microchip has expanded its popular lineup of secure, ARM Cortex M0+-based MCUs with the new SAM L22 series. The Atmel | SMART SAM L family is the highest scoring product family in the EEMBC ULPBench and offers an ultra-low power capacitive touch with a segment LCD controller that can deliver up to 320 segments, making the devices ideal for low-power applications such as thermostats, electric/gas/water meters, home control, medical and access systems.
The Internet of Things is driving connectivity in various battery-powered devices making security and ultra-low power critical features in these devices. With this in mind, the SAM L22 series boasts 256-bit AES encryption, cyclic redundancy check (CRC), a true random number generator, Flash protection and tamper detection to ensure information is securely stored, delivered and accessible. To get the lowest possible power consumption, the devices use Atmel’s proprietary picoPower technologies and smart low-power peripherals that work independently of the CPU in sleep modes. The latest MCU can run down to 39µA/MHz in active mode, consuming only 490nA with RTC in backup-mode.
“As more devices in the consumer, industrial and home automation segments are becoming smarter and connected, these devices require a number of unique features including ultra-low power, security, touch capability with an LCD — all features that are currently provided in the SAM L22,” explained Oyvind Strom, Atmel Senior Director of MCUs. “Atmel is already engaged with a number of alpha customers developing metering, thermostat and industrial automation solutions based on the new Atmel | SMART SAM L22 series.”
In addition to segment LCD supporting up to eight communication lines, capacitive touch sensing and built-in security measures, the SAM L22 includes up to 256KB of Flash and 32KB of SRAM, crystal-less USB device, programmable Serial Communication modules (SERCOM) and Atmel’s patented Event System and Sleepwalking technologies.
Those wishing to accelerate their designs will be happy to learn that the new SAM L22 Atmel Xplained Pro is now available. This professional evaluation board with an on-board debugger and standardized extension connectors is also fully supported by Atmel Studio. While the Atmel SAM L22 series is currently sampling, production release is slated for December 2015.
This blog originally appeared on Atmel Bits & Pieces.
  • Yasuhiko Koumoto
    Yasuhiko Koumoto over 10 years ago
    Hello,
    is the ULPBnech score of SAM L22 the same as SAM L21?
    Best regards,
    Yasuhiko Koumoto.
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Fidel Makatia
    Fidel Makatia
    • December 4, 2024
