Embedded and Microcontrollers blog Quick! Back EagleSoC on Kickstarter to get a Powerful Cortex-M3 Development Kit
  • arm cortex m3
  • psoc
  • psoc_creator
  • cypress
  • Cortex-M3
  • psoc5lp
  • cortex_m3
  • mcu
Mark Saunders
Mark Saunders
June 28, 2016
Time is running out. Don't miss the opportunity to get an EagleSoC development kit featuring a Cortex-M3 PSoC 5LP device.
I posted about this a couple of weeks ago and there is still time to back the kickstarter project. Here are the creators, explaining a little more about the kit.
The kits provide isolated analog and digital power domains so they are a great way to learn about Cortex-M, analog signal processing, and embedded systems programming in general. There is also a free software package called EZ-PSoC Library, which makes the job of interacting with device peripherals really simple.
I think these kits are great and so, if you're looking for a powerful but low-cost development kit with an 80MHz ARM device, don't wait too long and miss this opportunity!
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Fidel Makatia
    Fidel Makatia
    • December 4, 2024
