Embedded and Microcontrollers blog PSoC 4000S CapSense Prototyping Kit with Bluetooth Connectivity
  • capsense
  • psoc
  • psoc_creator
  • ble套件经验分享]
  • psoc4-ble
  • ble
Mark Saunders
Mark Saunders
December 2, 2016
[reprinted from PSoC Creator News and Information, author Pushek Madaan]
In September, 2016, we released our ultra-low-cost CY8CKIT-145-40XX PSoC 4000S CapSense PrototypingKit that enables CapSense-based user interface designs with Bluetooth connectivity. You can now buy this kit from the Cypress website or one of our channel partners.
CY8CKIT-145-40XX CapSense Prototyping Kit with Bluetooth Connectivity
PSoC 4000S CapSense Prototyping Kit (a.k.a. the butterfly kit) includes a variety of features, such as:
  • PSoC 4000S device - PSoC 4 with an ARM Cortex-M0+ core and Cypress's fourth-generation CapSense solution
  • Three capacitive touch buttons and a five-segment capacitive slider
  • Onboard EZ-BLE PRoC Module
  • KitProg2, an onboard programmer and debugger that also supports industry standard programming interfaces like CMSIS-DAP and Drag-n-Drop programming
  • Access to all the I/Os in a breadboard-compatible form factor
  • Snap-away form factor, allowing you to snap-away the KitProg2 or the CapSense boards for independent usage
To get started with the PSoC 4000S CapSense Prototyping Kit:
CY8CKIT-145 and PSoC Creator
  1. Buy the CY8CKIT-145-40XX PSoC 4000S CapSense Prototyping Kit
  2. Download and install the CY8CKIT-145-40XX PSoC 4000S CapSense Prototyping Kit Complete Setup software package
  3. Launch PSoC Creator and start a Code Example based project using CE201709 CapSense Linear Slider and Buttons.cywrk as the code example.
For more information, please visit www.cypress.com/CY8CKIT-145-40XX
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Fidel Makatia
    Fidel Makatia
    • December 4, 2024
