Embedded and Microcontrollers blog How to make a bootable SD card for SBC(Idea6410)
  • single_board_computer
  • sbc
lee_
lee_
July 2, 2014
It is for Boardcon Idea6410 SBC
1.1 Notes
1 please use standard SD card, within 2G Bytes, suggest selecting 1G/2G Kingston or Sandisk's genuine card.
2 Please via the USB card reader to write SDboot to SD card, try not to use the built-in notebook card reader; there are some built-in notebook SD card readers which can not write properly, even if successful to write, it will not boot correctly.
1.2 Steps
1 Insert SD card to USB card reader, and format the SD card to FAT32 in WindowsXP / Win7.
2 Open moviNAND_Fusing_Tool.exe in Windows XP / Win7.
3 Write SDboot.bin to SD card.
◆At the place of “SD/MMC Driver”, select the SD card’s mapped disc path in Windows XP
◆click “Browse” at the place of “Image file”,add SDboot.bin
◆ Click “START”
◆It will pop-up "Fusing image done" if successful to write, then click "OK" to finish the programming.
Notice: After successful programming, the written data can not be seen, and the capacity of the SD card does not change.
Idea6410 specifications:
SoC – ARM11 Samsung S3C6410, ARM1176JZF-S@up to 667MHz.
System Memory – 128MB Mobile DDR SDRAM, 266MHz, Samsung K4X51163PC
Storage – 256MB NAND Flash + SD/MMC card slot
Display – 4.3″ / 7″ resistive touchscreen
I/Os-
  • Audio I/O (3.5mm audio jack)
  • 100M Ethernet interface (RJ45)
  • USB2.0 Host
  • USB2.0 OTG
  • UART(RS232/TTL)
  • Camera interface (2x10-pin header, supporting the mode of ITU-R 601/656 8bit)
  • 2x5-pin JTAG
  • TVOUT, GPIO, SPI, ADC, IIC
Optional module: GPS, WIFI, Camera, USB Bluetooth,USB HUB+4x4 Matrix Keyboard and USB 3G Modem
Operating system: WinCE6.0, Linux2.6.28, Android2.3 and Ubuntu
Source: www.boardcon.com
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Fidel Makatia
    Fidel Makatia
    • December 4, 2024
