Embedded and Microcontrollers blog How to extract exception information form an exception stack frame
  • svc_call
  • exception_handling
  • Cortex-M
Yasuhiko Koumoto
Yasuhiko Koumoto
February 7, 2015
Hi all,
my presentation is related to Cortex-M exception handling. I have found the method to extract exception information form an exception stack frame.  Usually it can be done by getting the stack top by using the inline assembler as described in the post error: Hard Fault Handler. My presentation does not use the inline assembler. It will use the calling and receiving conventions of a function.
This procedure will be only valid under assumption the stack pointer is not switched. It means SPSEL bit of CONTROL register is "0".
As you know, arguments for a function will be passed via registers and the stack. In almost all case, the first 4 arguments will be passed via registers (i.e. r0, r1, r2 and r3) and as for after the 5th arguments will be passed via the stack. Therefore, for an exception handler declared as
void exception_handler(int a0, int a1, int a2, int a3, int a4, int a5, int a6, int a7, int a8, int a9, int a10, int a11)
    /* the body of the handler */
the stack contents just before calling the exception handler would be set from a4 to a11. That is,
   a0 ... register r0 value
   a1 ... register r1 value
   a2 ... register r2 value
   a3 ... register r3 value
   a4 ... stacked r0 (i.e. the same as a0)
   a5 ... stacked r1 (i.e. the same as a1)
   a6 ... stacked r2 (i.e. the same as a2)
   a7 ... stacked r3 (i.e. the same as a3)
   a8 ... stacked r12
   a9 ... stacked lr
   a10 .. stacked pc
   a11 .. stacked psr
If you want to get the SVCall parameter,
      scv_param = *(char *)(a10 - 2);
would be able to get it in the exception handler.
If you want to change the return address,
    *(short *)(&a10) = NEW_RETURN_ADDRESS;
would be realized it.
Although I have not seen it, for the compiler which had not adopted the register argument passing, it would be the a0 would be the stacked r0, the a1 would be the stacked r1, and so on.
How about my idea. Or someone had already mentioned it.
Best regards,
Yasuhiko Koumoto.
  • Liviu Ionescu
    Liviu Ionescu over 10 years ago
    As a conclusion, a proper exception processing requires accessing the CONTROL/MSP/PSP registers; although it can be done using the CMSIS inline functions, generally it is recommended to use an assembly function to determine if you are running on MSP or PSP and then call a C function and pass the pointer to the stack frame.
  • Yasuhiko Koumoto
    Yasuhiko Koumoto over 10 years ago
    Thank you for your confirmation. I also did the experiment again and have found you had been right.
    I will complain to the freescale guy.
    Best regards,
    Yasuhiko Koumoto.
  • Liviu Ionescu
    I recommend you get your information from the documentation, and not from various rumours.
    I just tried setting the CONTROL register to 2, and everything was fine, the value remained persistent and the next call used the PSP, not MSP.
    The test was performed on a FRDM KL25 board.
    Liviu
  • Yasuhiko Koumoto
    Hello Liviu,
    I already confirmed  CONTROL.SPSEL of all Kinetis MCUs are fixed to "0" by FRDM boards. Also a freescale guy agreed with it. It means my presentation is at least valid as for Kinetis MCU.
    Best regards,
    Yasuhiko Koumoto.
  • Liviu Ionescu
    > In Cortex-M0 case, CONTROL.SPSEL is fixed to 0
    I cannot confirm your statement. According to ARMv6-M Architecture Reference Manual, CONTROL.SPSEL is alive and well.
    > such as Kinetis L series... fix it to 0
    I cannot confirm that either.
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Fidel Makatia
    Fidel Makatia
    • December 4, 2024
