Embedded and Microcontrollers blog Eight-year-old Maker builds an Arduino-based smartwatch
  • Wearables
  • Arduino
  • smartwatch
  • zero
  • Cortex-M0+
  • sam
  • d20
Artie Beavis
Artie Beavis
August 18, 2015
Do you recall what you were doing back in the summer of fourth grade? Chances are you weren’t creating a programmable, Arduino-based smartwatch like eight-year-old Maker Omkar Govil-Nair, let alone starting your own business.
be3f2086ce5fef3fd7f5606aad2d094a_original
The O Watch is built around an Arduino Zero (Atmel | SMART SAM D21) module and packs quite the punch when it comes to portable computing. Not only can it tell time, the wearable device can run a wide range of games and applications. For instance, the smartwatch can calculate the value of Pi, play a recognizable version of “Flappy Bird,” “Pac-Man” and “Rock, Paper, Scissors,” and collect measurements in science experiments, among many other things.
Now live on Kickstarter, the O Watch will come in two different models: a base kit and a smartwatch kit. The first is comprised of a SAMD21G18A based programmer board along with a mini color OLED screen, a LiPo battery, a 3D-printed case, and a paracord available in four colors (orange, yellow, pink and blue). Meanwhile, the latter features all of that plus a sensor board equipped with a Honeywell three-axis compass, a Silicon Labs temperature and humidity sensor, and a Bosch barometric pressure sensor.
Pic1
To bring his idea to life, Govil-Nair has partnered with TinyCircuits for the design and manufacture of the watch’s electronic parts. Helping to reduce the gadget’s inner workings and thickness, TinyCircuits developed a new Arduino module with a color OLED screen, microUSB programmer and charger, all rolled into one board. The O Watch is driven by the highly-popular TinyDuino platform, while its integrated microUSB port is used for both charging and uploading programs.
“Since it’s a fully Arduino-compatible product in a tiny package, you can do a lot more – pretty much anything that is possible using a regular Arduino board and a color screen,” he explains.
701b064f1b34d0a84d6a46684ce4407f_original
What’s truly exciting about this project is that its programmability opens the door for young Makers to explore their imagination, enabling Arduino lovers of all ages to devise games and apps of their own that can be worn around the wrist.
Interestingly enough, Govil-Nair was inspired “to make his own product” after meeting our good friend and fellow whiz-kid Quin Etnyre at Maker Faire two years ago. And it looks like he’s well on his way to following in the footsteps of Etnyre with a successful crowdfunding campaign. The O Watch is currently seeking $15,000 on Kickstarter and expected to begin shipping in February 2016.
We can’t wait to see the wearable on display at the World Maker Faire in New York next month. Until then, ‘watch' it in action below!
This blog originally appeared on Atmel Bits & Pieces.
  • daith
    daith over 10 years ago
    Gah! You're just trying to make us feel inadequate. And it looks like something that could sell too. I think I'll go and strangle the kid
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Fidel Makatia
    Fidel Makatia
    • December 4, 2024
