Embedded and Microcontrollers blog Building an oscilloscope's DIY kit
  • arm cortex m3
  • welding
  • oscilloscope
  • diy
Jerome Decamps - 杜尚杰
June 8, 2016
There are a few days, I received my kit DiY for build an oscilloscope.
For sure I'm not hurry it comes from china more than 1 month  for the delivery...
If I make this page it's because this  project interest me, of course this build project DIY has an ARM processor.
A cortex M3 STM32F103c8T6 from STMicroelectronics for more specifications read this link :
STMicroelectronics Medium-density performance line Arm based 32-bit MCU
The first step is of course to control the content of the package and check there's no pieces missing.
And the all, with sorting and clearly identifying the components.
The preparation of the working environment is also very important .
A good lighting, being sure to be at quiet and with a good ventilation especially for welding fumes.
If like me you are not a pro of soldering, take your time. A project carried out in haste, never gives anything good !
As you can see in this picture. I had to resume SMD soldered too quickly made...
Once the SMD components properly placed , we will tackle the 'classic' components
In this photo : the back of the PCB before soldering. You will note the stalks bent to hold everything in place
Here we are! The resistors are all in place...
Let's go for the capacitors...
Next step, the  transistors and led to be continued...
Top Comments
  • Carl Williamson
    Carl Williamson over 9 years ago +1
    I love these worklogs. More pics!
  • G. Goodwin L. Pitos
    G. Goodwin L. Pitos over 9 years ago +1
    Jerome's work table is lovable too! Round with an overlay adorned with flowers and shells.
  • Jerome Decamps - 杜尚杰
    Jerome Decamps - 杜尚杰 over 9 years ago
    When one is gifted like me , there is no hole in the tablecloth. Especially if one is afraid of being yelled at by his wife
  • daith
    daith over 9 years ago
    It's worth getting a cheap ESD mat and wrist strap for doing things like that. There's lots of youtube videos about it which hopefully will inspire the fear of God in you about static.
    Plus there's less chance of burning a hole in the tablecloth
    For sure, i'm living near the sand and shells on the french riviera
    • Up +1 Down
    Welding is a process for joining or cutting materials (usually metals). When used for joining, the parts to be joined together are similar (in common welding methods) and portions in the vicinity of the joint melt with the filler during the process. Normally, mechanical strength is sought in the welded joint.
    Soldering is a  process for coupling metals. The materials to be attached need not be similar. The filler (solder) has lower melting point than the parts to be linked; hence, the parts don't melt only the solder does. Although soldering can also provide mechanical support to the parts soldered, in electronics, the primary purpose of soldering is electrical connection.
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Fidel Makatia
    Fidel Makatia
    • December 4, 2024
