Architectures and Processors blog White Paper - Solving Next Generation IP Configurability
  • socrates
  • White Paper
  • Arm
  • ip_tooling
  • ip-xact
  • configurability
  • configuration
  • White_paper
  • soc
  • ip
  • ip_integration
Ben Walshe
Ben Walshe
February 23, 2015
1 minute read time.
As a member of the team for ARM IP Tooling, one of the key challenges we see engineers face on a daily basis in 2015 is the need for IP configurability in system integration. Increases in IP reuse, IP configurability and system complexity within tightly bound schedules have compounded the problem of IP configurability and system integration for optimal end applications.
This whitepaper was written by the ARM IP Tooling Architect davidmurray and the IP Tooling Product Manager simonrance. They spend the majority of their time working on solutions for IP Integration through the ARM Socrates IP Tooling platform.
This white paper will preset the various types and complexities of IP configurability and how these can be managed effectively using IP-XACT and other means. It will also provide an overview of what is currently being done in the industry and demonstrate different types of configurability solutions.
System integration through configurable IP
This paper will then detail a system integration solution with configurable IP. The proposed solution can provide a standard mechanism to define conditionality and model configurability that can be leveraged across IP providers, IP consumers and EDA solution providers.
Please leave your feedback or any questions you may have and we will try our best to answer them.
See the ARM System IP webpage for more details.
Solving Next Generation IP Configurability.pdf
    Chris Walsh
    Chris Walsh
    • October 3, 2025
    Martin Weidmann
    Martin Weidmann
    • October 2, 2025
    Wathsala Vithanage
    Wathsala Vithanage
    • September 15, 2025
