    • Morello forum
    • SystemReady Forum
Architectures and Processors blog Porting to Arm 64-bit
  • Cortex-A53
  • Cortex-A57
  • White Paper
  • Armv8-A
  • 64-bit
Chris Shore
Chris Shore
April 8, 2016
Less than one minute read time.
This white paper is an introduction to porting existing code to the A64 instruction set supported by Armv8-A processors like the Cortex-A53 and Cortex-A57 from Arm. It will also be useful for those writing new code for these platforms.
Why 64-bit?
Diagram of evolution of Arm architecture
It seems that is a question with many answers! For some, it will be the need to address more than 4GB of memory, for others the need for wider registers and greater accuracy of 64-bit data processing, for still others the attraction of a larger register set.
Whatever your reason for looking to move to 64-bit, it is likely that you will have a body of legacy software which will need porting as well as new code which needs writing. This paper is designed to help with both processes.
We’ll start with a quick look at the evolution of the Arm architecture which has brought 64-bit to reality.
Download whitepaper
Porting to ARM 64-bit v4(2).pdf
  • Cliff Parris
    Cliff Parris over 7 years ago
    Chris, how do I get hold of a pdf version of your paper 'Porting to Arm 64-bit.pdf'
  • Jens Bauer
    Jens Bauer over 9 years ago
    If writing network code, I would certainly switch to Big Endian mode too; then I would need no byte-swap in software.
  • daith
    daith over 9 years ago
    I wonder if the section about the various options like ilp32 llp64 shouldn't be expanded a bit to be clearer about peoples options depending on where they are coming from and what they'll be running on. Plus it could mention big-endian options.
    For instance ilp32 could be useful for straight porting for speed but needs the appropriate libraries. The system structures in include files may not be identical to the ones for A32. Will user structures be exactly the same?
    ilp64 will not be supported at all
    Some machines may operate in big-endian mode e.g. when porting from MIPS or PowerPC. Support for one endian mode is very unlikely to be provided on the other except through virtualization.
    Apple do their own thing and reserve an extra register but otherwise support only ilp64 in 64 bit mode.
  • Jens Bauer
    This is a very good document. Thank you, Chris for this.
    (I'm using it as a guideline, so I can prepare my coding style for 64-bit, even though I haven't moved to Cortex-A yet. This means I'll perhaps be able to minimize the re-writing code cycle).
  • Juan Gao
    Juan Gao over 9 years ago
    Hi Chris,
    Do you have plan to put this doc in infocenter? It is useful.
    Thanks,
    Juan
  • Deep dive into the PMU value of L2D_CACHE_WR on the Neoverse N2 server
    Ker Liu
    Ker Liu
    In-depth analysis of what the PMU of L2D_CACHE_WR counts on the Neoverse N2 server.
    • April 15, 2024
  • Arm SPE: SoC Telemetry & Performance Analysis using Statistical Profiling Extension
    Brian Jeff
    Brian Jeff
    We refer to the SPE performance methodology whitepaper published by Arm for details on the content of this blog.
    • December 8, 2023
  • Implementing the WebAssembly bitmask operations on the 64-bit Arm architecture
    Anton Kirilov
    Anton Kirilov
    We discuss some of the challenges that we face when we are trying to implement the WebAssembly SIMD bitmask operations on the 64-bit Arm architecture.
    • December 6, 2023
