Given the enormous amount of resources compiled on the Community over the past few years, I thought it might be useful to some users to compile all the 'technical' resources in one document. The links below focus on resources for software engineers and developers (although not strictly!) rather than industry news, product releases and other non-technical content. I hope this is of use to some of you- bookmark it if it is so you can come back to it! If you feel I have missed anything then please leave a comment below with the blog/document linked to it. Cheers!
Getting Started with Arm Microcontroller and Assembly Programming
How to Load Constants in Assembly for Arm Architecture
Branch and Call Sequences Explained
Building Customized Debug and Trace Solutions for Multicore SoCs
Caches and Self-Modifying Code
Code Size: A Comprehensive Comparison of MicroMIPS32 and Thumb Code Size Using Many Megabytes of Customer Code
How to Call a Function from Arm Assembler
Designing in Arm: Part One- Switching Microcontrollers
Getting Started with Arm Assembly and C Programming
Detecting Overflow from MUL
The Armv8-A Architecture and its Ongoing Development
Enabling the Next Mobile Computing Revolution- Armv8 SoC Processors
Porting to Arm 64-bit
The A64 Instruction Set Architecture and Compilers
Armv8 Architecture: The Whys and Wherefores of AArch64 - 64-bit Applications
Coding Using NEON Technology
Coding for NEON: Part One- Load and Stores
Coding for NEON: Part Two- Dealing with Leftovers
Coding for NEON: Part Three- Matrix Multiplication
Coding for NEON: Part Four- Shifting Left and Right
Coding for NEON: Part Five- Rearranging Vectors
Virtualization on Arm with Xen
Virtualization on the Chromebook using KVM-tool
A Beginner’s Guide on Interrupt Latency - and Interrupt Latency of the Arm® Cortex®-M processors
Getting started with Arm Microcontroller Resources
Prototyping of Arm Cortex-M Processor Systems in FPGA
White Paper: Cortex-M for Beginners - An overview of the Arm Cortex-M processor family and comparison
A tour of the Cortex-M3 Core
From “Which Cortex-M processor” to “Which C compiler”
Arm Cortex-M0 assembly programming tips and tricks
10 useful tips to using the floating point unit on the Arm® Cortex®-M4 processor
Writing your own startup code for Cortex-M
Designing an SoC with an Arm Cortex-M Processor
Extending the CoreLink Cache Coherent Network Family
Extended System Coherency - Part 1 - Cache Coherency Fundamentals
Extended System Coherency - Part 2 - Implementation, big.LITTLE, GPU Compute and Enterprise
Extended System Coherency - Part 3 – Increasing Performance and Introducing CoreLink CCI-500
What is AMBA 5 CHI and how does it help?
