I'm trying to integrate NE10 into an application for Android. The version I downloaded was projectNe10-Ne10-v1.1.2-0-g75740a7.zip from the project ne10 website. I followed the instructions to create libNE10.a using this script :
#!/bin/bash
export ANDROID_NDK=/Users/<my_user>/android-ndk-r9d
export ANDROID_API_LEVEL=18
export ARM_ANDROID_TOOLCHAIN_VERSION=4.8
export ANDROID_TOOLCHAIN_PATH=/Users/<my_user>/android-ndk-r9d/toolchains/arm-linux-androideabi-4.8/prebuilt/darwin-x86_64/bin
mkdir build && cd build
cmake -DCMAKE_TOOLCHAIN_FILE=/Users/<my_user>/android-ndk-r9d/sources/projectNe10/android/android_config.cmake -DNE10_ENABLE_MATH=ON
make
I put the libNE10.a in projectNE10/lib in my JNI folder and copied the "inc" folder from the projectNE10 directory to projectNE10/include in my JNI folder.
I have added the library to my Android project by adding the following in my Android.mk:
include $(CLEAR_VARS)
LOCAL_MODULE := libNE10
LOCAL_SRC_FILES := projectNE10/lib/libNE10.a
include $(PREBUILT_STATIC_LIBRARY)
And I added the header files to my project by adding the following in my Android.mk:LOCAL_C_INCLUDES += $(LOCAL_PATH)/projectNE10/include
I have used this exact format for using ffmpeg and it works. However, with NE10 when I add #include "NE10.h" or #include "NE10_math.h" I get a ton of errors and the project does not compile.
If anyone can tell me what I am doing wrong or how to get rid of these errors that would really help me out! Thanks.
Here are the errors:
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 87 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 566 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1080 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 99 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1109 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 542 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1058 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 554 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1069 C/C++ Problem
expected declaration specifiers before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 75 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1170 C/C++ Problem
storage class specified for parameter 'ne10_abs_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1162 C/C++ Problem
storage class specified for parameter 'ne10_add_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 138 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 137 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1161 C/C++ Problem
storage class specified for parameter 'ne10_abs_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1160 C/C++ Problem
storage class specified for parameter 'ne10_add_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 136 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1181 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1173 C/C++ Problem
storage class specified for parameter 'ne10_add_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 150 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 149 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 654 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1172 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1171 C/C++ Problem
storage class specified for parameter 'ne10_add_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 148 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_physics.h /test/jni/test-jni/projectNE10/include line 113 C/C++ Problem
storage class specified for parameter 'ne10_add_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 123 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_physics.h /test/jni/test-jni/projectNE10/include line 104 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 111 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1120 C/C++ Problem
storage class specified for parameter 'ne10_abs_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 1159 C/C++ Problem
storage class specified for parameter 'ne10_add_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 135 C/C++ Problem
storage class specified for parameter 'ne10_add_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 126 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 125 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1131 C/C++ Problem
storage class specified for parameter 'ne10_add_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 124 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 690 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1223 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 720 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1235 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1192 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1184 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 161 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 666 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1183 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1182 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1195 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 678 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1194 C/C++ Problem
storage class specified for parameter 'ne10_abs_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1193 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 775 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1307 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 787 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1318 C/C++ Problem
old-style parameter declarations in prototyped function definition NE10_math.h /test/jni/test-jni/projectNE10/include line 75 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 733 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1247 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 746 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1278 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 319 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1368 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 331 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1379 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 295 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 799 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1329 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 307 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1357 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 890 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1429 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 902 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1456 C/C++ Problem
make.exe: *** [obj/local/armeabi/objs/test-jni/Platform.o] Error 1 test C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1407 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 878 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1418 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 956 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 968 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 914 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1466 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 944 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1476 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 530 C/C++ Problem
storage class specified for parameter 'ne10_len_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1067 C/C++ Problem
storage class specified for parameter 'ne10_len_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1059 C/C++ Problem
storage class specified for parameter 'ne10_len_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1057 C/C++ Problem
storage class specified for parameter 'ne10_len_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1078 C/C++ Problem
storage class specified for parameter 'ne10_len_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1070 C/C++ Problem
storage class specified for parameter 'ne10_len_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1068 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1028 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1020 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec3f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 1019 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1018 C/C++ Problem
storage class specified for parameter 'ne10_len_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1056 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1031 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec4f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 1030 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1029 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1129 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1121 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1119 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1132 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1130 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1107 C/C++ Problem
storage class specified for parameter 'ne10_len_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1081 C/C++ Problem
storage class specified for parameter 'ne10_len_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1079 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1118 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1110 C/C++ Problem
storage class specified for parameter 'ne10_normalize_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1108 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1221 C/C++ Problem
storage class specified for parameter 'ne10_cross_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1276 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1248 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1246 C/C++ Problem
storage class specified for parameter 'ne10_detmat_4x4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1305 C/C++ Problem
storage class specified for parameter 'ne10_cross_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1279 C/C++ Problem
storage class specified for parameter 'ne10_cross_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1277 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1233 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1224 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1222 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1245 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1236 C/C++ Problem
storage class specified for parameter 'ne10_dot_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1234 C/C++ Problem
storage class specified for parameter 'ne10_divc_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 828 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm2x2f_v2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 800 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm2x2f_v2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 798 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 840 C/C++ Problem
storage class specified for parameter 'ne10_divc_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 831 C/C++ Problem
storage class specified for parameter 'ne10_divc_float_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 830 C/C++ Problem
storage class specified for parameter 'ne10_divc_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 829 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm3x3f_v3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 785 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm4x4f_v4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 776 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm4x4f_v4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 774 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm2x2f_v2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 797 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm3x3f_v3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 788 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm3x3f_v3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 786 C/C++ Problem
storage class specified for parameter 'ne10_div_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 876 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 867 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec4f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 866 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 865 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 888 C/C++ Problem
storage class specified for parameter 'ne10_div_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 879 C/C++ Problem
storage class specified for parameter 'ne10_div_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 877 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 852 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 843 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec2f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 842 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 841 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 864 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 855 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec3f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 854 C/C++ Problem
storage class specified for parameter 'ne10_divc_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 853 C/C++ Problem
storage class specified for parameter 'ne10_divmat_4x4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 942 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 915 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 913 C/C++ Problem
storage class specified for parameter 'ne10_divmat_3x3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 954 C/C++ Problem
storage class specified for parameter 'ne10_divmat_4x4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 945 C/C++ Problem
storage class specified for parameter 'ne10_divmat_4x4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 943 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 900 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 891 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 889 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 912 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 903 C/C++ Problem
storage class specified for parameter 'ne10_vdiv_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 901 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1006 C/C++ Problem
storage class specified for parameter 'ne10_setc_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 998 C/C++ Problem
storage class specified for parameter 'ne10_setc_float_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 997 C/C++ Problem
storage class specified for parameter 'ne10_setc_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 996 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1017 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1009 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec2f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 1008 C/C++ Problem
storage class specified for parameter 'ne10_setc_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1007 C/C++ Problem
storage class specified for parameter 'ne10_divmat_2x2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 966 C/C++ Problem
storage class specified for parameter 'ne10_divmat_3x3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 957 C/C++ Problem
storage class specified for parameter 'ne10_divmat_3x3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 955 C/C++ Problem
storage class specified for parameter 'ne10_setc_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 995 C/C++ Problem
storage class specified for parameter 'ne10_divmat_2x2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 969 C/C++ Problem
storage class specified for parameter 'ne10_divmat_2x2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 967 C/C++ Problem
storage class specified for parameter 'ne10_invmat_4x4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1355 C/C++ Problem
storage class specified for parameter 'ne10_detmat_2x2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1330 C/C++ Problem
storage class specified for parameter 'ne10_detmat_2x2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1328 C/C++ Problem
storage class specified for parameter 'ne10_invmat_3x3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1366 C/C++ Problem
storage class specified for parameter 'ne10_invmat_4x4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1358 C/C++ Problem
storage class specified for parameter 'ne10_invmat_4x4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1356 C/C++ Problem
storage class specified for parameter 'ne10_detmat_3x3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1316 C/C++ Problem
storage class specified for parameter 'ne10_detmat_4x4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1308 C/C++ Problem
storage class specified for parameter 'ne10_detmat_4x4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1306 C/C++ Problem
storage class specified for parameter 'ne10_detmat_2x2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1327 C/C++ Problem
storage class specified for parameter 'ne10_detmat_3x3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1319 C/C++ Problem
storage class specified for parameter 'ne10_detmat_3x3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1317 C/C++ Problem
storage class specified for parameter 'ne10_transmat_3x3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1416 C/C++ Problem
storage class specified for parameter 'ne10_transmat_4x4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1408 C/C++ Problem
storage class specified for parameter 'ne10_transmat_4x4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1406 C/C++ Problem
storage class specified for parameter 'ne10_transmat_2x2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1427 C/C++ Problem
storage class specified for parameter 'ne10_transmat_3x3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1419 C/C++ Problem
storage class specified for parameter 'ne10_transmat_3x3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1417 C/C++ Problem
storage class specified for parameter 'ne10_invmat_2x2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1377 C/C++ Problem
storage class specified for parameter 'ne10_invmat_3x3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1369 C/C++ Problem
storage class specified for parameter 'ne10_invmat_3x3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1367 C/C++ Problem
storage class specified for parameter 'ne10_transmat_4x4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1405 C/C++ Problem
storage class specified for parameter 'ne10_invmat_2x2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1380 C/C++ Problem
storage class specified for parameter 'ne10_invmat_2x2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1378 C/C++ Problem
storage class specified for parameter 'ne10_identitymat_2x2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1474 C/C++ Problem
storage class specified for parameter 'ne10_identitymat_3x3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1467 C/C++ Problem
storage class specified for parameter 'ne10_identitymat_3x3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1465 C/C++ Problem
storage class specified for parameter 'ne10_identity_mat2x2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1477 C/C++ Problem
storage class specified for parameter 'ne10_identitymat_2x2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1475 C/C++ Problem
storage class specified for parameter 'ne10_identitymat_4x4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1454 C/C++ Problem
storage class specified for parameter 'ne10_trans_mat2x2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1430 C/C++ Problem
storage class specified for parameter 'ne10_transmat_2x2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1428 C/C++ Problem
storage class specified for parameter 'ne10_identitymat_3x3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 1464 C/C++ Problem
storage class specified for parameter 'ne10_identitymat_4x4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 1457 C/C++ Problem
storage class specified for parameter 'ne10_identitymat_4x4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 1455 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 85 C/C++ Problem
storage class specified for parameter 'ne10_addc_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 76 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 112 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 110 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 97 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 88 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 86 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 109 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 100 C/C++ Problem
storage class specified for parameter 'ne10_addc_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 98 C/C++ Problem
storage class specified for parameter 'ne10_addmat_4x4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 189 C/C++ Problem
storage class specified for parameter 'ne10_add_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 162 C/C++ Problem
storage class specified for parameter 'ne10_add_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 160 C/C++ Problem
storage class specified for parameter 'ne10_addmat_3x3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 201 C/C++ Problem
storage class specified for parameter 'ne10_addmat_4x4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 192 C/C++ Problem
storage class specified for parameter 'ne10_addmat_4x4f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 191 C/C++ Problem
storage class specified for parameter 'ne10_addmat_4x4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 190 C/C++ Problem
storage class specified for parameter 'ne10_add_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 147 C/C++ Problem
storage class specified for parameter 'ne10_add_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 159 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 256 C/C++ Problem
storage class specified for parameter 'ne10_subc_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 247 C/C++ Problem
storage class specified for parameter 'ne10_subc_float_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 246 C/C++ Problem
storage class specified for parameter 'ne10_subc_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 245 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 268 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 259 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec2f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 258 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 257 C/C++ Problem
storage class specified for parameter 'ne10_addmat_2x2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 213 C/C++ Problem
storage class specified for parameter 'ne10_addmat_3x3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 204 C/C++ Problem
storage class specified for parameter 'ne10_addmat_3x3f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 203 C/C++ Problem
storage class specified for parameter 'ne10_addmat_3x3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 202 C/C++ Problem
storage class specified for parameter 'ne10_subc_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 244 C/C++ Problem
storage class specified for parameter 'ne10_addmat_2x2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 216 C/C++ Problem
storage class specified for parameter 'ne10_addmat_2x2f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 215 C/C++ Problem
storage class specified for parameter 'ne10_addmat_2x2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 214 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 552 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 543 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 541 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 564 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 555 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 553 C/C++ Problem
storage class specified for parameter 'ne10_mul_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 528 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 518 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec4f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 517 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 516 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 540 C/C++ Problem
storage class specified for parameter 'ne10_mul_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 531 C/C++ Problem
storage class specified for parameter 'ne10_mul_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 529 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 624 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 613 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec2f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 612 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 611 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 638 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 627 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec3f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 626 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 625 C/C++ Problem
storage class specified for parameter 'ne10_mlac_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 596 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 567 C/C++ Problem
storage class specified for parameter 'ne10_vmul_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 565 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 610 C/C++ Problem
storage class specified for parameter 'ne10_mlac_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 599 C/C++ Problem
storage class specified for parameter 'ne10_mlac_float_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 598 C/C++ Problem
storage class specified for parameter 'ne10_mlac_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 597 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_float32_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 109 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 676 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_float32_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 104 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 667 C/C++ Problem
storage class specified for parameter 'ne10_fft_alloc_r2c_int16' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 101 C/C++ Problem
storage class specified for parameter 'ne10_fft_alloc_r2c_int32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 100 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 665 C/C++ Problem
storage class specified for parameter 'ne10_fft_alloc_r2c_float32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 99 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 688 C/C++ Problem
storage class specified for parameter 'ne10_fft_alloc_c2c_int16' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 97 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 679 C/C++ Problem
storage class specified for parameter 'ne10_fft_alloc_c2c_int32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 96 C/C++ Problem
storage class specified for parameter 'ne10_fft_alloc_c2c_float32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 95 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 677 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_float32_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 151 C/C++ Problem
storage class specified for parameter 'ne10_mla_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 652 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_int16_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 144 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 641 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_int16_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 139 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec4f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 640 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_int16_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 133 C/C++ Problem
storage class specified for parameter 'ne10_mlac_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 639 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_int32_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 128 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 664 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_int32_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 123 C/C++ Problem
storage class specified for parameter 'ne10_mla_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 655 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_int32_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 117 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_float32_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 113 C/C++ Problem
storage class specified for parameter 'ne10_mla_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 653 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_float32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 49 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_2x2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 744 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_3x3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 734 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_3x3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 732 C/C++ Problem
storage class specified for parameter 'ne10_mulcmatvec_cm4x4f_v4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 773 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_2x2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 747 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_2x2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 745 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_int16' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 89 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_4x4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 718 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_int16' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 84 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 691 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_int16' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 78 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_int32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 73 C/C++ Problem
storage class specified for parameter 'ne10_vmla_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 689 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_int32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 68 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_3x3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 731 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_int32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 62 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_4x4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 721 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_float32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 58 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_float32' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 54 C/C++ Problem
storage class specified for parameter 'ne10_mulmat_4x4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 719 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 305 C/C++ Problem
storage class specified for parameter 'ne10_sub_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 296 C/C++ Problem
storage class specified for parameter 'ne10_sub_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 294 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 317 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 308 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 306 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 280 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 271 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec3f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 270 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 269 C/C++ Problem
storage class specified for parameter 'ne10_sub_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 293 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 283 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec4f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 282 C/C++ Problem
storage class specified for parameter 'ne10_subc_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 281 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 370 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 361 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_float_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 360 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 359 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 382 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 373 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec2f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 372 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 371 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 329 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 320 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 318 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 358 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 332 C/C++ Problem
storage class specified for parameter 'ne10_sub_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 330 C/C++ Problem
storage class specified for parameter 'ne10_submat_3x3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 436 C/C++ Problem
storage class specified for parameter 'ne10_submat_4x4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 426 C/C++ Problem
storage class specified for parameter 'ne10_submat_4x4f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 425 C/C++ Problem
storage class specified for parameter 'ne10_submat_4x4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 424 C/C++ Problem
storage class specified for parameter 'ne10_submat_2x2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 449 C/C++ Problem
storage class specified for parameter 'ne10_submat_3x3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 439 C/C++ Problem
storage class specified for parameter 'ne10_submat_3x3f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 438 C/C++ Problem
storage class specified for parameter 'ne10_submat_3x3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 437 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 394 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 385 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec3f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 384 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 383 C/C++ Problem
storage class specified for parameter 'ne10_submat_4x4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 423 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec4f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 397 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec4f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 396 C/C++ Problem
storage class specified for parameter 'ne10_rsbc_vec4f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 395 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec3f' NE10_math.h /test/jni/test-jni/projectNE10/include line 503 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 494 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec2f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 493 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 492 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec4f' NE10_math.h /test/jni/test-jni/projectNE10/include line 515 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec3f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 506 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec3f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 505 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec3f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 504 C/C++ Problem
storage class specified for parameter 'ne10_mulc_float' NE10_math.h /test/jni/test-jni/projectNE10/include line 479 C/C++ Problem
storage class specified for parameter 'ne10_submat_2x2f_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 452 C/C++ Problem
storage class specified for parameter 'ne10_submat_2x2f_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 451 C/C++ Problem
storage class specified for parameter 'ne10_submat_2x2f_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 450 C/C++ Problem
storage class specified for parameter 'ne10_mulc_vec2f' NE10_math.h /test/jni/test-jni/projectNE10/include line 491 C/C++ Problem
storage class specified for parameter 'ne10_mulc_float_asm' NE10_math.h /test/jni/test-jni/projectNE10/include line 482 C/C++ Problem
storage class specified for parameter 'ne10_mulc_float_neon' NE10_math.h /test/jni/test-jni/projectNE10/include line 481 C/C++ Problem
storage class specified for parameter 'ne10_mulc_float_c' NE10_math.h /test/jni/test-jni/projectNE10/include line 480 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 298 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 73 C/C++ Problem
storage class specified for parameter 'ne10_fir_sparse_float_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 281 C/C++ Problem
storage class specified for parameter 'ne10_img_rotate_rgba' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 77 C/C++ Problem
storage class specified for parameter 'ne10_fir_lattice_float_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 276 C/C++ Problem
storage class specified for parameter 'ne10_img_resize_bilinear_rgba' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 50 C/C++ Problem
storage class specified for parameter 'ne10_fir_interpolate_float_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 271 C/C++ Problem
storage class specified for parameter 'ne10_img_resize_bilinear_rgba_c' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 58 C/C++ Problem
storage class specified for parameter 'ne10_fir_decimate_float_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 266 C/C++ Problem
storage class specified for parameter 'ne10_img_boxfilter_rgba8888' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 104 C/C++ Problem
storage class specified for parameter 'ne10_fir_float_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 261 C/C++ Problem
storage class specified for parameter 'ne10_img_boxfilter_rgba8888_c' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 111 C/C++ Problem
storage class specified for parameter 'ne10_fir_sparse_init_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 252 C/C++ Problem
storage class specified for parameter 'ne10_img_rotate_rgba_c' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 85 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 100 C/C++ Problem
storage class specified for parameter 'ne10_fir_lattice_init_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 247 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 376 C/C++ Problem
storage class specified for parameter 'ne10_iir_lattice_float_c' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 362 C/C++ Problem
storage class specified for parameter 'ne10_iir_lattice_init_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 353 C/C++ Problem
storage class specified for parameter 'ne10_img_boxfilter_rgba8888_neon' NE10_imgproc.h /test/jni/test-jni/projectNE10/include line 118 C/C++ Problem
storage class specified for parameter 'ne10_iir_lattice_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 347 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 340 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 328 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 318 C/C++ Problem
expected '=', ',', ';', 'asm' or 'attribute' before 'asm' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 308 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_int16_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 191 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_int16_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 186 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_int16_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 180 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_int32_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 175 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_int32_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 170 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2c_1d_int32_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 164 C/C++ Problem
storage class specified for parameter 'ne10_fft_c2r_1d_float32_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 160 C/C++ Problem
storage class specified for parameter 'ne10_fft_r2c_1d_float32_neon' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 156 C/C++ Problem
storage class specified for parameter 'ne10_fir_interpolate_init_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 240 C/C++ Problem
storage class specified for parameter 'ne10_fir_decimate_init_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 233 C/C++ Problem
storage class specified for parameter 'ne10_fir_init_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 227 C/C++ Problem
storage class specified for parameter 'ne10_fir_sparse_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 219 C/C++ Problem
storage class specified for parameter 'ne10_fir_lattice_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 214 C/C++ Problem
storage class specified for parameter 'ne10_fir_interpolate_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 209 C/C++ Problem
storage class specified for parameter 'ne10_fir_decimate_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 204 C/C++ Problem
storage class specified for parameter 'ne10_fir_float' NE10_dsp.h /test/jni/test-jni/projectNE10/include line 199 C/C++ Problem
storage class specified for parameter 'ne10_physics_compute_aabb_vec2f' NE10_physics.h /test/jni/test-jni/projectNE10/include line 47 C/C++ Problem
storage class specified for parameter 'ne10_physics_apply_impulse_vec2f' NE10_physics.h /test/jni/test-jni/projectNE10/include line 58 C/C++ Problem
storage class specified for parameter 'ne10_physics_relative_v_vec2f' NE10_physics.h /test/jni/test-jni/projectNE10/include line 52 C/C++ Problem
storage class specified for parameter 'ne10_physics_relative_v_vec2f_c' NE10_physics.h /test/jni/test-jni/projectNE10/include line 73 C/C++ Problem
storage class specified for parameter 'ne10_physics_compute_aabb_vec2f_c' NE10_physics.h /test/jni/test-jni/projectNE10/include line 68 C/C++ Problem
storage class specified for parameter 'ne10_physics_compute_aabb_vec2f_neon' NE10_physics.h /test/jni/test-jni/projectNE10/include line 93 C/C++ Problem
storage class specified for parameter 'ne10_physics_apply_impulse_vec2f_c' NE10_physics.h /test/jni/test-jni/projectNE10/include line 79 C/C++ Problem
I have found the problem. It is the "LOCAL_CONLYFLAGS := -std=c99" in my Android.mk. If I add this line to the android test project provided in NE10 then the same errors I am getting when I build my project, I also get when I build that project.
How can I use c99 without getting these errors? Does projectNE10 not work in c99?
The problem has been answered at:NE10.h include errors · Issue #76 · projectNe10/Ne10 · GitHub
Thanks.
