Build failed for a baremetal
hello,
While I am trying to execute a simple bubble sort program in c as provided as an example in the arm development studio IDE, I am facing 3 errors like as shown below:  (Target and source must be capability)
/bubblesort.c:45:37: error: invalid target type 'uint32_t *' (aka 'unsigned int *') for __cheri_tocap: target must be a capability
    seq_t sequence = (__cheri_tocap seq_t)malloc(sizeof(uint32_t) * SEQ_LEN);
../bubblesort.c:57:33: error: invalid source type 'uint32_t *' (aka 'unsigned int *') for __cheri_fromcap: source must be a capability
    free((__cheri_fromcap void*)sequence);
/bubblesort.c:70:6: error: conflicting types for 'print'
void print (seq_t __cheri_input sequence, int size) {
N.B: I am using LLVM 13.0.0 with Morello support.
  • llvm-objcopy takes the input as first argument, and optionally the output as second argument (see the man page). Looks like they're swapped.
  • Many thanks, Kevin. What I noticed is that in line number 24 as compared to my previous code instead of $PROGRAM_NAME, if I replace it with $PROGRAM_NAME.elf after -o, there itself the elf is getting generated. However, is there are any need to run line 25 to generate the elf then..with the llvm-objcopy? Or what is the purpose of executing line 25 please?
    # COMPILATION SCRIPT
    # Script based on instructions from:
    # https://git.morello-project.org/morello/docs/-/blob/morello/release-1.6/standalone-baremetal-readme.rst
    # First argument = program name (must match basename of .c file)
    PROGRAM_NAME=$1
    PWD=`pwd`
    TOOLCHAIN=/opt/llvm-project-releases-morello-baremetal-release-1.6
    # COMPILE PROGRAM
    #new technique
    $TOOLCHAIN/bin/clang -target aarch64-none-elf -march=morello -c $PROGRAM_NAME.c -o $PROGRAM_NAME.o -O3 -g
    $TOOLCHAIN/bin/clang -target aarch64-none-elf -o $PROGRAM_NAME.elf $PROGRAM_NAME.o -Wl,--image-base,0xe0000000
    #$TOOLCHAIN/bin/llvm-objcopy -O binary $PROGRAM_NAME.elf $PROGRAM_NAME
  • Your new version is correct. Using llvm-objcopy is required to generate a raw binary that can be used as non-secure payload, as suggested in the instructions. You cannot directly use an ELF executable as payload.
  • Many thanks, Kevin for the information. Once I apply the script to generate the elf as shown in line no 25 (script shown below), the elf is generating but I am not sure once I try to view the elf file by right-clicking and viewing through the elf content editor it displays that it is not a valid elf file.
    PROGRAM_NAME=$1
    PWD=`pwd`
    # COMPILE PROGRAM
    #new technique
    $TOOLCHAIN/bin/clang -target aarch64-none-elf -o $PROGRAM_NAME $PROGRAM_NAME.o -Wl,--image-base,0xe0000000
    $TOOLCHAIN/bin/llvm-objcopy -O binary $PROGRAM_NAME $PROGRAM_NAME.elf
  • ok so is this version correct? changed line 24 with $PROGRAM_NAME.elf after -o and in line 25 used $PROGRAM_NAME.elf as first argument instead of the second as shown below.
    _
    PROGRAM_NAME=$1
    PWD=`pwd`
    # COMPILE PROGRAM
    #new technique
