Morello Board: fail to progress to UEFI boot menu
My Morello Board (MB) fails to progress to the UEFI menu,
no "Press ESCAPE for boot options". I have done the following:
1) I have updated the MB internal SDcard to the latest
Arm M1SDP MCC Firmware v2.3.0
Build Date: Apr 19 2022
2) I have build a bootable USB memory stick with a ready to use binary image copied from www.cheribsd.org
cm770@pursuit2:/camb/carloscheri$ sudo dd if=cheribsd-memstick-arm64-aarch64c-22.05p1.img of=/dev/sdc conv=fsync bs=1M
[sudo] password for cm770:
777+1 records in
777+1 records out
814955008 bytes (815 MB, 777 MiB) copied, 124.943 s, 6.5 MB/s
3) I have tried to reboot from the image on mu USB memory but it seems that the Morello Board does not recognise (or detect) the bootable image on my memory stick. It never progresses to the UEFI boot menu.
4) I have tried:
a) Five different memory sticks with the dowloaded binary image mentiones in 2) and with an image that I have created with cherybuild.by
-rw-r--r-- 1 cm770  cm770  773732864  Jul 31 17:57 FreeBSD-14.0-CURRENT-arm64-aarch64c-memstick.img
b) I have created the bootable USB drive from unbunto 18.04 and on MacOS
c) I have tried the bootable USB sticks on a second Morello Board (I have two of them).
d) I have plugged the USD stick on different ports (4 of them)  of the Morello Board.
e) I have turned off the Morello Board, waited for several minutes before turning it on  again.
I always fails and produces the same outputs.  I'm attaching them. 1 to 3 are preliminary steps. The outcomes from the reboot process are at the end 4 to 6.
Can someone tell from the outputs if the problem is :
a) Firmware software on the SDcard
b) Incorrect software of the bootable image
c) Incorrect creation of the bootable image with the dd command. For example, wrong partition of the USB mem stick. I have formatted it on ubunto, single partition, "compatible with all systems and devices (MRB/DOS).
MorelloBoardFails toReach_UEFIboot.txt
Sun 31 Jul 22:52:10 BST 2022
1) I have produced a bootable USB mem stick
cm770@pursuit2:/camb/carloscheri$ lsblk
sdb      8:16   0 465.8G  0 disk
└─sdb1   8:17   0 465.8G  0 part /camb
sdc      8:32   1  58.2G  0 disk
sr0     11:0    1  1024M  0 rom
777+1 records in
777+1 records out
2) sync
cm770@pursuit2:/camb/carloscheri$ sync
3) I have upgraded the Morello board internal SDcard
cm770@pursuit2:/$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sdc      8:32   1   1.9G  0 disk
└─sdc1   8:33   1   1.9G  0 part /media/cm770/M1SDP
3.1) mount SDcard
cm770@pursuit2:/$ sudo mount /dev/sdc1 /mnt
cm770@pursuit2:~$ sudo mount /dev/sdc1 /mnt
cm770@pursuit2:~$ ls /mnt
config.txt  ee0364b.txt  LIB  LICENSES	MB  SOFTWARE
3.2) Remove old files from SDcard
cm770@pursuit2:~$ sudo rm -R /mnt/*
3.3 Copy new files to SDcard
cm770@pursuit2:~$ sudo cp -rf /camb/carloscheri/board-firmware-morello-mainline/* /mnt
cm770@pursuit2:~$ ls -l /mnt
total 192
-rwxr-xr-x 1 root root  1199 Jul 31 23:24 config.txt
-rwxr-xr-x 1 root root   215 Jul 31 23:24 ee0364b.txt
drwxr-xr-x 2 root root 32768 Jul 31 23:24 LIB
drwxr-xr-x 5 root root 32768 Jul 31 23:24 LICENSES
drwxr-xr-x 3 root root 32768 Jul 31 23:24 MB
drwxr-xr-x 2 root root 32768 Jul 31 23:24 SOFTWARE
cm770@pursuit2:~$ sync
3.4 umount SDcard to prevent corruption
cm770@pursuit2:~$ sudo umount /dev/sdc1
4) I have plugged to bootable USB stick to one of the
USB ports of the Morello board and turned it ON
Cmd>
Arm M1SDP MCC Boot loader v1.0.0
HBI0364 build 534
MCC: Power On
MCC to access SD card request acknowledged.
Clear ULINK JTAG
Time :  22:27:25
Date :  31:07:2022
Powering up system...
Clear ULINK JTAG
Time :  22:27:32
Date :  31:07:2022
Switching on ATXPSU...
Switching on main power...
12V Rail Check Pass
Reading Board File \MB\HBI0364B\io_v010f.txt
TOTAL OSCCLKS: 15
PMIC RAM configuration (80_1_86G.bin)...
Temperature (deg C)
Outlet = 30.9 PMIC   = 39.1 SoC = 37.1 IN2  = 33.9 IN1 = 32.9
MidBrd = 39   PCIeSW = 41   MCC = 36.2 FPGA = 35.0 SoC Fan Speed = 9%
ALERT off
Configuring motherboard (rev B, var A)...
Configuring FPGA from file \MB\HBI0364B\io_v010f.bit
Address: 0x007E0000
FPGA configuration complete.
Config clocks num: 15
OSCCLK0  : 50.000000MHz
OSCCLK1  : 50.000000MHz
OSCCLK2  : 50.000000MHz
OSCCLK3  : 50.000000MHz
OSCCLK4  : 50.000000MHz
OSCCLK5  : 50.000000MHz
OSCCLK6  : 50.000000MHz
OSCCLK7  : 50.000000MHz
OSCCLK8  : 75.000000MHz
OSCCLK9  : 85.000000MHz
OSCCLK10  : 12.288000MHz
OSCCLK11  : 50.000000MHz
OSCCLK12  : 50.000000MHz
OSCCLK13  : 50.000000MHz
OSCCLK14  : 170.000000MHz
OSCCLK setup: PASSED
GTXCLK setup: PASSED
EEPROM config found
File to compare \MB\HBI0364B\pci_v002.bin \MB\HBI0364B\pci_v002.bin
UPDATE IN PROGRESS
PCIe PEX I2C configuration
PCIe I2C R/W test passed...
Reading PCIe EEPROM file \MB\HBI0364B\pci_v002.bin
DMA TX Handler
Address: 0x00000017
PCIe EEPROM programmed
Writing SCC 0x014 with ACLK 50000000 Hz
Writing SCC 0x00C with 0x00000003
Writing SCC 0x020 with 0x06090805
Writing SCC 0x024 with 0x06060606
Writing SCC 0x028 with 0x00000606
Writing SCC 0x1160 with 0x00000001
Writing SCC 0x1164 with 0x01000000
Writing SCC 0x1168 with 0x00000000
Writing SCC 0x116C with 0x00000000
Writing SCC 0x1180 with 0x00000000
Writing SCC 0x1184 with 0x0000000C
Writing SCC 0x1188 with 0x00000000
Writing SCC 0x118C with 0x00000000
Writing SCC 0x1190 with 0x00000000
Writing SCC 0x1194 with 0x00000000
Writing SCC 0x1198 with 0x00000000
Writing SCC 0x119C with 0x00000000
Reading SCC 0xFF8 with 0x0A364A08
Reading SCC 0xFFC with 0x41050000
QSPI Controller detected id = 0x4000303
Device ID 0x20, 0xBB, 0x19
Setting QSPI dummy clocks...
Dummy clocks already set
Updating SCP qspi with PCC bios
File \MB\HBI0364B\pcc_v055.bin written to MCC memory address 0x65F00000
DMA TX Handler
PCC Bios updated from \MB\HBI0364B\pcc_v055.bin
Waiting for PCC to copy boot loader from QSPI...
Powering down...
SPI Write command to PCC: register 3 cmd 0xD003 tx data 0x1
SPI Return data from PCC: register 3 cmd 0x2000 rx data 0x0
Resetting board.
Clear ULINK JTAG
HBI0364 build 534
MCC: Power On
Clear ULINK JTAG
Time :  22:28:15
Date :  31:07:2022
Clear ULINK JTAG
Time :  22:28:20
Date :  31:07:2022
12V Rail Check Pass
TOTAL OSCCLKS: 15
Temperature (deg C)
Outlet = 30.9 PMIC   = 38.4 SoC = 35.1 IN2  = 32.9 IN1 = 32.2
MidBrd = 38   PCIeSW = 40   MCC = 36.2 FPGA = 35.0 SoC Fan Speed = 9%
ALERT off
Address: 0x007E0000
EEPROM config found
Reading images file \MB\HBI0364B\images.txt
Updating MCP file
File \SOFTWARE\mcp_fw.bin written to MCC memory address 0x64000000
DMA TX Handler
Image: mcp_fw updated from \SOFTWARE\mcp_fw.bin
Updating SCP file
File \SOFTWARE\scp_fw.bin written to MCC memory address 0x64000000
DMA TX Handler
Image: scp_fw updated from \SOFTWARE\scp_fw.bin
Updating AP QSPI file
File \SOFTWARE\fip.bin written to MCC memory address 0x66000000
DMA TX Handler
Image: fip updated from \SOFTWARE\fip.bin
PCIe mac address = 0002 F70098FF
PCC mac address = 0002 F70098FE
LAN9221 was identified successfully.
MAC addrs test: PASSED
SMC MAC address 0002-F700-9900
Identifying DDR 0
Device Information
Manufacturer ID = 80 2C
Module Part Number = 9ASF1G72PZ-2G9E1
Module Serial Number = F2 E C2 0
Identifying DDR 1
Device Information
Module Serial Number = F2 E BF D8
Setting System LEDs[7:4]
Setting PCIe_nPERST/PCIESW_PERSTN
PCIe control C2C disabled
APUART0 connected to USBPORT_3
SCPUART connected to USBPORT_4
MCPUART connected to USBPORT_5
PL031 Date & Time set = Sun Jul 31 22:29:18 2022
QSPI test (0x6403FEF8):0xFFFFFFFF
Releasing SOC_nPOR/SOC_nSRST
SPI Write command to PCC: register 3 cmd 0xD003 tx data 0x2
USB Serial Number = 500541683016
Cmd>
5) Show Firmware
Cmd> ?
Build Time: 13:40:34
+ command ------------------+ function ---------------------------------+
| CAP "fname" [/A]          | captures serial data to a file            |
|                           |  [/A option appends data to a file]       |
| FILL "fname" [nnnn]       | create a file filled with text            |
|                           |  [nnnn - number of lines, default=1000]   |
| TYPE "fname"              | displays the content of a text file       |
| REN "fname1" "fname2"     | renames a file 'fname1' to 'fname2'       |
| COPY "fin" ["fin2"] "fout"| copies a file 'fin' to 'fout' file        |
|                           |  ['fin2' option merges 'fin' and 'fin2']  |
| DEL "fname"               | deletes a file                            |
| DIR "[mask]"              | displays a list of files in the directory |
| FORMAT [label]            | formats Flash Memory Card                 |
| USB_INIT                  | Re-initialize USB                         |
| USB_ON                    | Enable usb                                |
| USB_OFF                   | Disable usb                               |
| SHUTDOWN                  | Shutdown PSU (leave micro running)        |
| REBOOT                    | Power cycle system and reboot             |
| RESET                     | Reset Board using CB_nRST                 |
| IOFPGA_VERSION            | Displays IOFPGA Version                   |
| DEBUG                     | Enters debug menu                         |
| EEPROM                    | Enters eeprom menu                        |
| HELP  or  ?               | displays this help                        |
| THE FOLLOWING COMMANDS ARE ONLY AVAILABLE IN RUN MODE                 |
| CASE_FAN_SPEED "SPEED"    | SLOW, MEDIUM, FAST, 0%, 10%, 20%, .. 100% |
| READ_AXI "fname"          | Read system memory to file 'fname'        |
|          "address"        | from address to end address               |
|          "end_address"    |                                           |
| WRITE_AXI "fname"         | Write file 'fname' to system memory       |
|           "address"       | at address                                |
Cmd> DIR
File System Directory...
CONFIG.TXT                                         1.199   31.07.2022  22:24
EE0364B.TXT                                          215   31.07.2022  22:24
LIB                                          -DIR-         31.07.2022  22:24
LICENSES                                     -DIR-         31.07.2022  22:24
MB                                           -DIR-         31.07.2022  22:24
TRASH-~1                                     -DIR-         08.06.2022  22:39
SOFTWARE                                     -DIR-         31.07.2022  22:24
LOG.TXT                                            1.507   01.01.2016  12:00
                      3 File(s)                    2.921 bytes
                      5 Dir(s)             1.994.489.856 bytes free.
Cmd> USB_ON
Enabling debug USB...
Cmd>
6) I have tried to reboot from bootable USB stick.
Cmd> reboot
Rebooting...
Disabling debug USB..
Clear ULINK JTAG
Board rebooting...
Clear ULINK JTAG
Time :  22:32:36
Date :  31:07:2022
12V Rail Check Pass
TOTAL OSCCLKS: 15
Temperature (deg C)
Outlet = 30.9 PMIC   = 41.9 SoC = 37.0 IN2  = 33.2 IN1 = 34.3
MidBrd = 42   PCIeSW = 49   MCC = 38.4 FPGA = 38.6 SoC Fan Speed = 9%
ALERT off
Address: 0x007E0000
EEPROM config found
Identifying DDR 0
Device Information
Identifying DDR 1
Device Information
PL031 Date & Time set = Sun Jul 31 22:32:55 2022
Cmd>
  • Hi Carlos,
    From MCC firmware wise the boot is done and I don't see any errors in the MCC log. Could you please paste the SCP and AP console logs?
    Regards,
    Manoj
  • As requested, I'm sending the outcomes (attached file)  from
    1) MCC
    2) PCC
    3) AP
    Let me know if you see something unusual. Thanks!
    MCC_PCC_AP_outcome_1Jul2022.txt
    1 Jul 2022
     * 1) minicom -D /dev/ttyUSB0  /* MCC outcome */
    Cmd> ?
    |          "end_address"    |                                           |
    Cmd>
    Cmd> reboot
    Rebooting...
    Clear ULINK JTAG
    Board rebooting...
    Clear ULINK JTAG
    Time :  13:09:24
    Date :  01:08:2022
    12V Rail Check Pass
    TOTAL OSCCLKS: 15
    Temperature (deg C)
    Outlet = 30.4 PMIC   = 40.9 SoC = 36.1 IN2  = 32.4 IN1 = 33.9
    MidBrd = 41   PCIeSW = 47   MCC = 37.7 FPGA = 37.2 SoC Fan Speed = 9%
    ALERT off
    Address: 0x007E0000
    EEPROM config found
    Identifying DDR 0
    Device Information
    Identifying DDR 1
    Device Information
    PL031 Date & Time set = Mon Aug  1 13:09:43 2022
    Cmd>
     * 2) minicom -D /dev/ttyUSB1   /* PCC outcome */
    F2P_SS_RSTREQ ignored because IOFPGA is powered off.
    Received reset request from SoC via F2P_SS_RSTREQ.
    F2PCC_INT triggered by IOFPGA, nothing to do here.
    Sent reg 2000   cmd 0000   data 0000
    Received reg D003   cmd 0000   data 0002
    MCC Request Command detected
    PCC FMC GPIO init request
    PCC FMC GPIO init complete
     * 3) minicom -D /dev/ttyUSB2   /* AP outcome */
    NOTICE:  Booting Trusted Firmware
    NOTICE:  BL1: v2.4(debug):37a5f702b
    NOTICE:  BL1: Built : 14:51:05, Jan 27 2021
    INFO:    BL1: RAM 0x4074000 - 0x407f000
    INFO:    Using crypto library 'mbed TLS'
    INFO:    Loading image id=6 at address 0x4001010
    INFO:    Image id=6 loaded: 0x4001010 - 0x40014c6
    INFO:    Loading image id=31 at address 0x4001010
    INFO:    Image id=31 loaded: 0x4001010 - 0x4001154
    INFO:    FCONF: Config file with image ID:31 loaded at address = 0x4001010
    INFO:    Loading image id=24 at address 0x4001300
    INFO:    Image id=24 loaded: 0x4001300 - 0x40013e8
    INFO:    FCONF: Config file with image ID:24 loaded at address = 0x4001300
    INFO:    BL1: Loading BL2
    INFO:    Loading image id=1 at address 0x4057000
    INFO:    Image id=1 loaded: 0x4057000 - 0x406b919
    NOTICE:  BL1: Booting BL2
    INFO:    Entry point address = 0x4057000
    INFO:    SPSR = 0x3c5
    INFO:    FCONF: Reading FW_CONFIG firmware configuration file from: 0x4001010
    INFO:    FCONF: Reading firmware configuration information for: dyn_cfg
    INFO:    FCONF: Reading TB_FW firmware configuration file from: 0x4001300
    INFO:    FCONF: Reading firmware configuration information for: tbbr
    NOTICE:  BL2: v2.6(debug):morello-master-base-2250-ga5441df74
    NOTICE:  BL2: Built : 07:00:11, Mar 28 2022
    WARNING: FCONF: Invalid config id 23
    WARNING: FCONF: Invalid config id 25
    INFO:    BL2: Doing platform setup
    INFO:    Zeroing DDR memory range 0x80000000 - 0xFFFFFFFF
    INFO:    BL2: Loading image id 3
    INFO:    Loading image id=7 at address 0x4045000
    INFO:    Image id=7 loaded: 0x4045000 - 0x404560e
    INFO:    Loading image id=9 at address 0x4045000
    INFO:    Image id=9 loaded: 0x4045000 - 0x40454da
    INFO:    Loading image id=13 at address 0x4045000
    INFO:    Image id=13 loaded: 0x4045000 - 0x4045430
    INFO:    Loading image id=3 at address 0x4045000
    INFO:    Image id=3 loaded: 0x4045000 - 0x405115c
    INFO:    BL2: Skip loading image id 23
    INFO:    BL2: Skip loading image id 25
    INFO:    BL2: Loading image id 5
    INFO:    Loading image id=11 at address 0xe0000000
    INFO:    Image id=11 loaded: 0xe0000000 - 0xe00004ea
    INFO:    Loading image id=15 at address 0xe0000000
    INFO:    Image id=15 loaded: 0xe0000000 - 0xe0000440
    INFO:    Loading image id=5 at address 0xe0000000
    INFO:    Image id=5 loaded: 0xe0000000 - 0xe0200000
    INFO:    BL2: Loading image id 27
    INFO:    Loading image id=27 at address 0xfef00000
    INFO:    Image id=27 loaded: 0xfef00000 - 0xfef00126
    INFO:    SDS: Detected SDS Memory Region (3520 bytes)
    NOTICE:  BL1: Booting BL31
    INFO:    Entry point address = 0x4045000
    INFO:    SPSR = 0x3cd
    NOTICE:  BL31: v2.6(debug):morello-master-base-2250-ga5441df74
    NOTICE:  BL31: Built : 07:00:11, Mar 28 2022
    INFO:    GICv3 without legacy support detected.
    INFO:    ARM GICv3 driver initialized in EL3
    INFO:    Maximum SPI INTID supported: 991
    INFO:    Initializing SCMI driver on channel 0
    INFO:    SCMI driver initialized
    INFO:    Total DIMM size: 16GB
    INFO:    Zeroing DDR memory range 0x8080000000 - 0x8400000000
    INFO:    Configuring DMC Bing in server mode
    INFO:    Enabling ECC on DMCs
    INFO:    BL31: Initializing runtime services
    INFO:    BL31: rainier: CPU workaround for 1868343 was applied
    INFO:    BL31: Preparing for EL3 exit to normal world
    INFO:    Entry point address = 0xe0000000
    INFO:    SPSR = 0x3c9
    add-symbol-file /home/ubuntu/morello-1.4/bsp/uefi/edk2/Build/morellosoc/DEBU0
    Loading PEIM at 0x000E0039160 EntryPoint=0x000E0039240 PcdPeim.efi
    Loading PEIM at 0x000E0005160 EntryPoint=0x000E0005240 MemoryInit.efi
    Memory Init PEIM Loaded
     Memory Map
    Description                     :        START       -        END         [ }
    Generic Watchdog                : 0x000000002A440000 - 0x000000002A45FFFF [ }
    GIC-600                         : 0x0000000030000000 - 0x000000003003FFFF [ }
    GICR-600                        : 0x00000000300C0000 - 0x00000000301BFFFF [ }
    non-secure SRAM                 : 0x0000000006000000 - 0x000000000600FFFF [ }
    UART0                           : 0x000000002A400000 - 0x000000002A40FFFF [ }
    DDR Primary                     : 0x0000000080000000 - 0x00000000FEFFFFFF [ }
    DDR Secondary                   : 0x0000008080000000 - 0x00000083FFFFFFFF [ }
    AP QSPI flash device            : 0x000000001A000000 - 0x000000001BFFFFFF [ }
    Expansion Peripherals           : 0x000000001C000000 - 0x000000001D2FFFFF [ }
    PCIe ECAM Region                : 0x00000028C0000000 - 0x00000028CFFFFFFF [ }
    PCIe MMIO32 & IO Region         : 0x0000000060000000 - 0x000000006F3FFFFF [ }
    PCIe MMIO64 Region              : 0x0000000900000000 - 0x00000028BFFFFFFF [ }
    CCIX ECAM Region                : 0x0000004FC0000000 - 0x0000004FCFFFFFFF [ }
    CCIX MMIO32 & IO Region         : 0x0000000070000000 - 0x000000007F3FFFFF [ }
    CCIX MMIO64 Region              : 0x0000003000000000 - 0x0000004FBFFFFFFF [ }
    Virtual Memory Table setup complete.
    Loading PEIM at 0x000FEFDF160 EntryPoint=0x000FEFDF240 PeiCore.efi
    Loading PEIM at 0x000FEFD7160 EntryPoint=0x000FEFD7240 PcdPeim.efi
    Loading PEIM at 0x000FEFD3160 EntryPoint=0x000FEFD3240 PlatformPei.efi
    Platform PEIM Loaded
    Loading PEIM at 0x000FEFC8160 EntryPoint=0x000FEFC8240 DxeIpl.efi
    Loading PEIM at 0x000FE7F0160 EntryPoint=0x000FE7F0240 CpuPei.efi
    Loading PEIM at 0x000FE79D000 EntryPoint=0x000FE79E000 DxeCore.efi
    Loading DXE CORE at 0x000FE79D000 EntryPoint=0x000FE79E000
    HOBLIST address in DXE = 0xFE53C018
    Memory Allocation 0x00000004 0xE0000000 - 0xE01FFFFF
    Memory Allocation 0x00000004 0xFEFFF000 - 0xFEFFFFFF
    Memory Allocation 0x00000004 0xFEFFE000 - 0xFEFFEFFF
    Memory Allocation 0x00000004 0xFEFFD000 - 0xFEFFDFFF
    Memory Allocation 0x00000004 0xFEFFC000 - 0xFEFFCFFF
    Memory Allocation 0x00000004 0xFEFFB000 - 0xFEFFBFFF
    Memory Allocation 0x00000004 0xFEFFA000 - 0xFEFFAFFF
    Memory Allocation 0x00000004 0xFEFF9000 - 0xFEFF9FFF
    Memory Allocation 0x00000004 0xFEFF8000 - 0xFEFF8FFF
    Memory Allocation 0x00000004 0xFEFF7000 - 0xFEFF7FFF
    Memory Allocation 0x00000004 0xFEFF6000 - 0xFEFF6FFF
    Memory Allocation 0x00000004 0xFEFF5000 - 0xFEFF5FFF
    Memory Allocation 0x00000004 0xFEFF4000 - 0xFEFF4FFF
    Memory Allocation 0x00000004 0xFE77D000 - 0xFE79CFFF
    Memory Allocation 0x00000003 0xFEFDF000 - 0xFEFF3FFF
    Memory Allocation 0x00000003 0xFEFD7000 - 0xFEFDEFFF
    Memory Allocation 0x00000003 0xFEFD3000 - 0xFEFD6FFF
    Memory Allocation 0x00000003 0xFEFC8000 - 0xFEFD2FFF
    Memory Allocation 0x00000004 0xFEFB8000 - 0xFEFC7FFF
    Memory Allocation 0x00000004 0xFE7F5000 - 0xFEFB7FFF
    Memory Allocation 0x00000003 0xFE7F0000 - 0xFE7F4FFF
    Memory Allocation 0x00000003 0xFE79D000 - 0xFE7EFFFF
    Memory Allocation 0x00000004 0xFE77C000 - 0xFE77CFFF
    Memory Allocation 0x00000004 0xF7000000 - 0xF701FFFF
    FV Hob            0xE0000000 - 0xE01FFFFF
    FV Hob            0xFE7F5008 - 0xFEFB7F47
    FV2 Hob           0xFE7F5008 - 0xFEFB7F47
                      00000000-0000-0000-0000-000000000000 - 9E21FD93-9C72-4C15-2
    FV3 Hob           0xFE7F5008 - 0xFEFB7F47 - 0x0 - 0x1
    Loading driver at 0x000FE6C4000 EntryPoint=0x000FE6C503C PcdDxe.efi
    Loading driver at 0x000F96B0000 EntryPoint=0x000F96C003C RuntimeDxe.efi
    Loading driver at 0x000FE6BD000 EntryPoint=0x000FE6BE03C Metronome.efi
    Loading driver at 0x000F9610000 EntryPoint=0x000F962003C ResetSystemRuntimeDi
    Loading driver at 0x000FE6B0000 EntryPoint=0x000FE6B103C SecurityStubDxe.efi
    Loading driver at 0x000FE6A2000 EntryPoint=0x000FE6A303C AcpiTableDxe.efi
    Loading driver at 0x000FE67C000 EntryPoint=0x000FE67D03C HiiDatabase.efi
    Loading driver at 0x000FE674000 EntryPoint=0x000FE67503C ConfigurationManagei
    Loading driver at 0x000FE641000 EntryPoint=0x000FE64203C DynamicTableFactoryi
    Loading driver at 0x000FE63A000 EntryPoint=0x000FE63B03C SerialDxe.efi
    Loading driver at 0x000FE631000 EntryPoint=0x000FE63203C ArmGicDxe.efi
    Loading driver at 0x000FE61D000 EntryPoint=0x000FE61E03C DevicePathDxe.efi
    Loading driver at 0x000FE616000 EntryPoint=0x000FE61703C ArmPciCpuIo2Dxe.efi
    Loading driver at 0x000FE60F000 EntryPoint=0x000FE61003C DpcDxe.efi
    Loading driver at 0x000FE607000 EntryPoint=0x000FE60803C HttpUtilitiesDxe.efi
    Loading driver at 0x000FE5F8000 EntryPoint=0x000FE5F903C ArmCpuDxe.efi
    Loading driver at 0x000FE5ED000 EntryPoint=0x000FE5EE03C FaultTolerantWriteDi
    Loading driver at 0x000FE5E5000 EntryPoint=0x000FE5E603C DynamicTableManageri
    Loading driver at 0x000FE5DE000 EntryPoint=0x000FE5DF03C GenericWatchdogDxe.i
    Loading driver at 0x000FE5D7000 EntryPoint=0x000FE5D803C ArmTimerDxe.efi
    Loading driver at 0x000FE5B4000 EntryPoint=0x000FE5B503C SetupBrowser.efi
    Loading driver at 0x000FE593000 EntryPoint=0x000FE59403C BdsDxe.efi
    Loading driver at 0x000FE57D000 EntryPoint=0x000FE57E03C httpDynamicCommand.i
    Loading driver at 0x000FE56B000 EntryPoint=0x000FE56C03C tftpDynamicCommand.i
    Loading driver at 0x000F9560000 EntryPoint=0x000F957003C CadenceQspiDxe.efi
    Detected n25q256a SPI NOR flash with page size 256 B, erase size 4 KB, totalB
    Loading driver at 0x000FE559000 EntryPoint=0x000FE55A03C RamDiskDxe.efi
    Loading driver at 0x000F94F2000 EntryPoint=0x000F94F303C DisplayEngine.efi
    Loading driver at 0x000FE546000 EntryPoint=0x000FE54703C PciHostBridgeDxe.efi
    RootBridge: PcieRoot(0x0)
      Support/Attr: 0 / 0
        DmaAbove4G: Yes
    NoExtConfSpace: No
         AllocAttr: 3 (CombineMemPMem Mem64Decode)
               Bus: 0 - FF Translation=0
                Io: 0 - 3FFFFF Translation=0
               Mem: 60000000 - 6EFFFFFF Translation=0
        MemAbove4G: 900000000 - 28BFFFFFFF Translation=0
              PMem: FFFFFFFFFFFFFFFF - 0 Translation=0
       PMemAbove4G: FFFFFFFFFFFFFFFF - 0 Translation=0
    RootBridge: Acpi(PNP0A09,0x0)
      Support/Attr: 0 / 0
        DmaAbove4G: Yes
    NoExtConfSpace: No
               Mem: 70000000 - 7EFFFFFF Translation=0
        MemAbove4G: 3000000000 - 4FBFFFFFFF Translation=0
    Loading driver at 0x000F9490000 EntryPoint=0x000F94A003C VariableRuntimeDxe.i
    Loading driver at 0x000F9705000 EntryPoint=0x000F970603C PlatformDxe.efi
    Loading driver at 0x000F93D0000 EntryPoint=0x000F93E003C RealTimeClock.efi
    InitializeRealTimeClock: using default timezone/daylight settings
    Loading driver at 0x000F9330000 EntryPoint=0x000F934003C CapsuleRuntimeDxe.ei
    Loading driver at 0x000F9290000 EntryPoint=0x000F92A003C MonotonicCounterRuni
    ASSERT [VariableRuntimeDxe] VariableParsing.c(502): NameSizeOfVariable (PtrT0
  • >>May I know what you mean by 'control is not transferred to the >>MCC'?
    Ignore that, sorry. I understand better now. I though that the AP would return some control to the MCC console during booting process.
    The AP console just runs independently (without accepting any keyword input) till it gets stuck.
    It DOES NOT ACCEPT any keyword input during the booting process, not  at:
    1) Press ESCAPE for boot options ...........
    2) Welcome to Cheri
        1. Boot Multi user [Enter]
         2.Boot Single user
         7. Boot options
    3) Console type [xterm]:
    AP runs wildly till it gets stuck at 3). After point 3 I can switch to MCC console, reboot and get the same result. I have tried
    a)- A binary downloaded img
    b) Two img compiled locally with cheribuild.py
    FreeBSD-14.0-CURRENT-arm64-aarch64c-mini-memstick.img
    I'm using sudo minicom -D /dev/ttyUSB2
    configured as "115200 8N1"
    I have tried 3 different keywords.
    The result is the same.
    Any ideas would be truly appreciated, even if they don't solve the prob.
    Carlos
