Dear ARM forum,
I am writing a OpenGLES2.0 based graphics application.
I am trying to find some quick answers to my questions.
1. what are all the compressed Texture formats Mali 400 support? (in RGB and YUV )
2. what are all the uncompressed Texture formats Mali 400 support? (in RGB and YUV )
3. What are all the frame-buffer output formats does Mali 400 support? (in RGB and YUV)
Thanks,
Ravinder Are
Hi Ravinder,
The Mali-400 GPU supports up to OpenGL ES 2.0.
There are no compressed texture formats that are core in GLES2.0, however we do support ETC1 format for compressed textures.
As for uncompressed, we support the formats described in the spec. Please look at the glTexImage2D man page for details.
Regarding YUV support, this depends on the version of the DDK you have.
Assuming Android...
For input format support, using the GL_OES_EGL_image_external extension:
r3p0:
r4p1-01rel0:
r7p0:
For output format support:
Render to texture, FBO - r7p0 - All of the above mentioned YUV formats.
EGL recordable, Render to framebuffer:
r5p1-01rel0:
I hope that helped in answering your questions.
Kind Regards,
Michael McGeagh
Thanks Michael for your reply,
I am using Linux OS, and my Mali400 version is r5p1-01rel0.
Could you please also list exactly for this.
I am planning to do a VP only PP only based stress test on my GPU, Could you suggest and share some test that are available freely. If I want to capture VP specific performance numbers and PP specific performance numbers, what are all performance numbers do you suggest in interest.
Specifically for Linux and r5p0, the list is:
Input:
Output:
Render to texture, FBO - Same as input
Regarding stress testing, it sounds like you are wanting to create microbenchmarks. I am unfamiliar with public free microbenchmarks so have no suggestions to give.
Hope that helps.
Thanks Michael, for quick information.
Could you please add the RGB formats as well.
I see all you captured are YUV formats only.
All of the RGB formats are listed in the OpenGL ES 2.0 specification. There are lots of them, so not going to list them all here ...
In additionwe support a few extra via extensions. See this list, particuarly GL_ARM_rgba8, GL_OES_rgb8_rgba8, GL_EXT_texture_format_BGRA8888:
http://malideveloper.arm.com/learn-about-mali-hub/mali-utgard-architecture-extensions/
HTH, Pete
Thanks Peter for the information.
