SIMD Comparaison result and use
hi,
when i do the diff
    // Compute diff
    int32x4_t diff1_4 = vabsq_s32(vsubq_s32(A, B));
I got 4 result. One for each test (A1,B1)(A2,B2)(A3,B3) and (A4,B4)
And than i have to do the comparaison
    uint32x4_t mask1_4 = vcltq_s32(diff1_4, X);
So in "uint32x4_t mask1_4" i got the comparaison for each test, so 4 résult.
the answer on post "SIMD help for exemple" was to use
    if (vmaxvq_u32(mask1_4) > 0) { ... }
I thinks my sentence was confuse in the previous post. I wrote
   " if (mask1_4[0] > 0 && mask1_4[1] > 0)  and if (mask1_4[2] > 0 && mask1_4[3] > 0) "
but it is not    if(  mask1_4[0] > 0  &&  mask1_4[1] > 0  &&   mask1_4[2] > 0  &&  mask1_4[3] > 0) )
i need to do 2 test
   if (mask1_4[0] > 0 && mask1_4[1] > 0){
        process data1
  if (mask1_4[2] > 0 && mask1_4[3] > 0){
      process data2
I think that vmaxvq_u32(mask1_4) will check all the comparaison. like
    if(  mask1_4[0] > 0 && mask1_4[1] > 0  &&   mask1_4[2] > 0 && mask1_4[3] > 0  )
PS: i think i should have post it in the old post
  • i think i may be found what i need but i am not sure.
    here is how i see the code:
        // Compute diff
        // Comparee diff
        // extract [0] and [1] from mask1_4
        uint32x2_t mask1_4_01 = vget_high_u32(mask1_4); // not sure high is [0][1]
        // extract [2] and [3] from mask1_4
        uint32x2_t mask1_4_23 = vget_low_u32(mask1_4);
       if (vmaxvq_u32(mask1_4_01 ) > 0){ process data1 } // it is like i check   if (mask1_4[0] > 0 && mask1_4[1] > 0)
       if (vmaxvq_u32(mask1_4_23 ) > 0){ process data2 } // it is like i check   if (mask1_4[2] > 0 && mask1_4[3] > 0)
    is this correct or did i miss something. Or is there a better way to do it ?
  • Yes, that looks good to me.
  • i spend 3 hours debuging NEON code until now.
    but  "vmaxvq_u32(mask1_4_01 ) " does not compile "error: no matching function for call to 'vmaxvq_u32"
    it look like vmaxvq_u32 is for 128bits,"uint32x4_t", long and not 64bits,"uint32x2_t". I tried to find the correct function but without result.
    i tried to use vmin_u32 and vmax_u32 but it look like it is a comparaison of 2 uint32x2_t. Not usefull in my context.
    I need an vmaxvq_u32 or vminvq_u32 how work with uint32x2_t.
    But i can use "if ( mask1_4[0]  > 0 && mask1_4[1]  > 0) because "uint32x4_t mask1_4 = vcltq_s32(diff1_4, constseuil);" return -1 when the comparaison is OK and 0 when it is not.
    Something wrong with vmaxvq_u32( uint32x2_t) .
    PS: concerning the extraction. high is not  [0][1] but [2][3]
  • why if ( mask1_4[0]  > 0 && mask1_4[1]  > 0) work with a -1 value. It does look at the sign ?
    same thing if i use vcltq_u32.
    by the way if (  (mask1_4[0]+mask1_4[1]) > 1 ) does not  work in all the case.
    in fact i tested namy solution.
    lets said a have
    int32x4_t diff1_4  = vabsq_s32(vsubq_s32(xv, yv));
    mask1_4    -1  -1  -1  -1    if i add  (mask1_4[0]+mask1_4[1]) i got -2
    but if i check
    if ( (mask1_4[0]+mask1_4[1])  < 0)     it is false
    if ( (mask1_4[0]+mask1_4[1])  == -2) it istrue
    if ( (mask1_4[0]+mask1_4[1])  <  -1) it istrue
    if ( (mask1_4[0]+mask1_4[1])  > 0)   it istrue
    there is a problem !   < 0 should be true and > 0 false.
    here is the complete code :
    __attribute__((noinline)) void neon_multi(){
        int A1[4] = {300,400,600,400};
        int B1[4] = {300,400,600,400};//= {,600,400,300,400};
        int32x4_t constseuil = vdupq_n_s32(4);
        int* x_base = (A1);
        int32x4_t xv = vld1q_s32(x_base);
        int* y_base = (B1);
        int32x4_t yv = vld1q_s32(y_base);
        // Compute diff
        // Compute diff
        int32x4_t yv_swap = vextq_u32(yv, yv, 2);
        int32x4_t diff5_8 = vabsq_s32(vsubq_s32(xv, yv_swap));
        // Generate diff conditions
        LOGE(" neon_multi mask1_4 %3d %3d %3d %3d \n",mask1_4[0],mask1_4[1],mask1_4[2],mask1_4[3]);
        LOGE(" neon_multi test %3d %3d \n",(mask1_4[0]+mask1_4[1]),(mask1_4[2]+mask1_4[3]));
        uint32x4_t mask5_8 = vcltq_s32(diff5_8, constseuil);
        LOGE(" neon_multi mask5_8 %3d %3d %3d %3d \n",mask5_8[0],mask5_8[1],mask5_8[2],mask5_8[3]);
        LOGE(" neon_multi test %3d %3d \n",(mask5_8[0]+mask5_8[1]),(mask5_8[2]+mask5_8[3]));
        if ( (mask1_4[0]+mask1_4[1])    > 0){LOGE(" neon_multi 1  %3d\n",(mask1_4[0]+mask1_4[1]));}
        if ( (mask1_4[0]+mask1_4[1])    < 0){LOGE(" neon_multi 2  %3d\n",(mask1_4[0]+mask1_4[1]));}
        if ( (mask1_4[0]+mask1_4[1]) == -2){LOGE(" neon_multi 3  %3d\n",(mask1_4[0]+mask1_4[1]));}
        if ( (mask1_4[0]+mask1_4[1])   < -1){LOGE(" neon_multi 4  %3d\n",(mask1_4[0]+mask1_4[1]));}
    let's see tomorow ;))
  • it look like vmaxvq_u32 is for 128bits,"uint32x4_t", long and not 64bits,"uint32x2_t". I tried to find the correct function but without result.
    NEON intrinsics are relatively regular in terms of naming convention, the "q" versions are 128-bit quad-word versions, the non-q versions are 64-bit double-word versions.
    So vmaxvq_u32() is the 128-bit version, and vmaxv_u32() is the 64-bit version.
    mask1_4 is an unsigned uint32 type, so 4294967295 not -1. NEON compares just return a vector with all bits set if true, or all bits clear for false, which is useful for use in logical bitwise mask operations.
  • i check it pomorow.
    and thanks again. I spend 6 hours on neon today. I am full. ;))
  • hi,
    vmaxv_u32() work fine. And i anderstoud the problem for >0 and < 0. It look like it is a problem of printf using signed and unsigned integer type. that is way i always see -1 for signed and unsigned.
    but i stil do not anderstand why if i use unsigned int.
    uint32x4_t mask1_4 = vcltq_u32(diff1_4, constseuil);
    the check is true for > 0 and at the same time == -2 and < -1. it is quite confusing.
    how unsigned can respond to == -2 and < -1.
    If i were using signed i would anderstand because signed check true for < 0, == -2 and < -1. wich is logic.
    do i miss one include in my program to avoid unsigned int to answer true to == -2 and < -1. for the == -2 i can, let said andertand. but for < -1 i do not. it is not logic that positive number can be inferieur at -1. It is the first time i see something like that. ;))
  • t look like it is a problem of printf using signed and unsigned integer type.
    You need to use "%d" for signed and "%u" for unsigned.
    In your original code your diff1_4 is signed and you were using "vcltq_s32" which is the signed compare, so the compare should be correct for signed values.
    The result of all of the NEON compare functions is not really meaningful as a number - it's just a bitmask with all bits in a lane set to 1 if the compare, like vcltq_s32, passed and zero if it failed. Given it's not expected to be interpreted as a number, the result is always uint32_t no matter what the original compare data type was, and the only comparison that matters is whether that mask is zero or non-zero.
  • i just read your response when i was writting my. ;))
    sorry for the prévious post. I anderstoud the problem. Using %u rather than %d give me the response.
    it look like -1 is converted to unsigned int during the < -1
    so -1 = 4294967295 and -2 = 4294967294 so  4294967294 is  <  to 4294967295.
    but i is really confusing.
    Thanks very much for your answer. I was confuse at the begining of the day. Now i can go back to my program calmly, ;))
    have a good day.
  • sorry again, i just forgot to ask. what is the best in term of performance.
    extract and compare
    uint32x2_t mask1_4_01 = vget_low_u32(mask1_4); then  if ( vminv_u32(mask1_4_01) > 0)
    or
    if (mask1_4[0] > 0 && mask1_4[1] > 0 ){
    I think it is good for me then.
    and thanks again.
  • I suspect they are going to end up exactly the same
