hardware processing difference between OpenCL and OpenGL
hi,
As i anderstoud OpenGL and OpenCL use différent driver to process their command on GPU and I wonder how the GPU procees those command. Is there a pin for OpenCL command and a pin for OpenGL command ?
So openCL will use a spécific part of the GPU and OpenGL another part of the GPU. I ask this because OpencL work with matrice and openGL work with vector except is i use compute shader and image.
But using OpenGL it is hard to retreive data to CPU. So i conclude that their are two différent part in the GPU.
Could someone explain how it work on the porocessor.
thanks.
  • using OpenGL it is hard to retreive data to CPU
    Why? You can glMapBuffer, just the same as you can with a CL buffer.
  • Yes you are rigth , i already use it to transfert texture to java after readpixel using PBO. few years ago ;))
    But the main question was about GPU architecture. Is there a part of the GPU used OpenCL and a part used for OpenGL ?
    Are booth of them using the same memorie ?
  • Sorry for the new post. But i did some test using OpenCL and OpenGL at the same time.
    I find out that it take 50% even 100% more time to procees image.
    So, the rigth question would be does OpenCL and OpenGL run in parrallel on
    GPU or do their share something that can produce a bootle neck at some momment.
    If you like i can send you a debug result.
    By the way after some amount of image processing between 60 and 100. The procees time can double enven more.
    May be you know why so i could improve my code.
  • There aren't dedicated parts of the GPU for OpenCL vs OpenGL - they can both use the shader cores / memory etc, and the drivers will use all the shader cores they need, so if the processing is large enough that it can use all the cores, then the OpenCL & OpenGL workloads will most likely go one after the other.
  • thanks,
    But the diuble time processing appends also when using only OpenCL. For exemple using OpenCL alone after 60/100 frames i can go from 63ms per frame to 100ms. Using OpenCL and OpenGL it is from 63ms to up to 200ms.
    In this case it isnt a problem of core used. So, it loock like this could be comming fron some where else. It is just my analyze. That is why i asked thequesion.
    By the way when GPU start to slow donw the CPU pocesing is also slowing. It look more like mémorie acces problem or heat problem after 60/100 frames.
  • i did some test today and i foud out that the problem come from the masive use of multicore threading and big data processing. But no idéa why this slow donw the GPU.
