Continuous Integration on Streamline
I'm Android device developer.
I'd like to prepare CI(Continuous Integration) environment using Streamline.
Is CI supporting for not only "Application Profiling" but also "System Profiling" setting ?
https://developer.arm.com/documentation/102009/0903/Running-Performance-Advisor-in-continuous-integration-workflows/Generate-performance-reports-automatically
According to this documentation, streamline_me.py is needed.
In my understanding, streamline_me.py is not used in case of "System Profiling" because this script needs to specify some target application for capturing.
Thus, I guess CI is only supporting "Application Profiling", is it correct ?
I know that Performance Advisor is not supported on "System Profiling".
So, I also want to know that apc file generation on "System Profiling" by CLI command is available or not.
Best Regards
