eglCreatePixmapSurface for Mali-400 under linux
Hello everybody.
I am working on Mali-400 under linux. I want to create pixmap surface, but it always return EGL_BAD_MATCH error.
Here attribut list wich i use for eglChooseConfig
EGLint EGLRuntime::configAttributes[] =
        /* DO NOT MODIFY. */
        /* These attributes are in a known order and may be re-written at initialization according to application requests. */
        EGL_SAMPLES,             0,
        EGL_ALPHA_SIZE,          0,
        EGL_RED_SIZE,            8,
        EGL_GREEN_SIZE,          8,
        EGL_BLUE_SIZE,           8,
        EGL_BUFFER_SIZE,         32,
        EGL_STENCIL_SIZE,        0,
        EGL_RENDERABLE_TYPE,     0,
        EGL_SURFACE_TYPE,        EGL_PIXMAP_BIT ,
        EGL_DEPTH_SIZE,          24,
        EGL_NONE
Here pixmap structure
typedef struct fbdev_pixmap
        unsigned int height;
        unsigned int width;
        unsigned int bytes_per_pixel;
        unsigned char buffer_size;
        unsigned char red_size;
        unsigned char green_size;
        unsigned char blue_size;
        unsigned char alpha_size;
        unsigned char luminance_size;
        fbdev_pixmap_flags flags;
        unsigned short *data;
} fbdev_pixmap;
fbdev_pixmap tempPixMap;
  tempPixMap.height = windowH;
  tempPixMap.width = windowW;
  tempPixMap.buffer_size = 32;
  tempPixMap.red_size = 8;
  tempPixMap.green_size = 8;
  tempPixMap.blue_size = 8;
  tempPixMap.alpha_size = 0;
  tempPixMap.data = (unsigned short *)BitMapPtr;
  tempPixMap.flags = FBDEV_PIXMAP_SUPPORTS_UMP;
Here eglCreatePixmapSurface function call
surface = eglCreatePixmapSurface(display, config, (EGLNativePixmapType)(&tempPixMap), NULL);
What i am doing wrong?
Thanks.
  • Hi,
    Nothing seems overly obvious from what you showed, so we would need more information in order to figure this out.
    Do you have a small reproducer so we can begin investigation?
    Kind Regards,
    Michael McGeagh
  • Thanks, for reply.
    The problem solved.
    I was allocated memory without using UMP's API.
    ump_result umpResult;
    umpResult = ump_open();
    if( umpResult == UMP_ERROR )
    printf("Sorry, can't open UMP, exiting...\n ");
    exit(1);
    pixmapHandle =  ump_ref_drv_allocate( sizeOfBuffer  , UMP_REF_DRV_CONSTRAINT_NONE);
    tempPixMap.bytes_per_pixel = 4;
    tempPixMap.alpha_size = 8;
    tempPixMap.luminance_size = 0;
    tempPixMap.data = (unsigned short *)pixmapHandle;
  • Hi Ako6, could you read back the gpu result from  pixmapHandle in this way?
