Problem in running mali cube in Mali open GL ES emulator 1.4.1
I downloaded the Mali open GL ES emulator 1.4.1 from the mali developer tools website and even installed visual c++ redistributable packages for visual studio 2013 for windows 7 64-bit on my pc.
Still, when i run the "mali cube" application, a window appears and disappears suddenly. I am not able to find out what the problem is?
Is there someone who can help me. Thanks in advance.
Sudlin
