if Laptop continuous using means better with air conditioner or fan?
If a laptop is used continuously for long hours, it is better to use it in a room with an air conditioner rather than just a fan. An air conditioner helps maintain a lower and stable room temperature, which prevents the laptop from overheating and improves overall performance and lifespan. A fan only circulates warm air and may not be effective in reducing heat during heavy usage. Regular air conditioner service is also important to ensure proper cooling efficiency and clean airflow, which further helps protect electronic devices like laptops from heat-related damage.
