Arm Compiler 5 supports the following ARM architectures
Hi
I'm "Lightning Flash" Asuna
Does Arm Compiler 5 support the Armv8-M architecture for Cortex-M23 and M33?
and
Is there a website that lists the Arm architectures supported by Arm Compiler 5?
Please help.
My boss is angry.
  • Arm Compiler 5 (armcc) only supports up to Armv7-M processors.
    You need to use Arm Compiler 6 (armclang) or the new Arm Compiler for Embedded (clang).
    For a complete list of supported processors use "armcc --cpu list" on the command line.
  • I appreciate your support.
    I've confirmed that Armv8-M is not available.
    I'll tell my boss that I need Arm Compiler v6.
    Thank you!
    C:\Keil\MDK543\ARM\ARMCompiler_506_Windows_x86_b960\bin>armcc --cpu list
    The following arguments to option 'cpu' can be selected:
    --cpu=4
    --cpu=4T
    --cpu=5T
    --cpu=5TE
    --cpu=5TEJ
    --cpu=6-M
    --cpu=6S-M
    --cpu=7-R
    --cpu=7-M
    --cpu=7E-M
    --cpu=ARM7EJ-S
    --cpu=ARM7TDMI
    --cpu=ARM720T
    --cpu=ARM7TDMI-S
    --cpu=ARM9TDMI
    --cpu=ARM920T
    --cpu=ARM922T
    --cpu=ARM9E-S
    --cpu=ARM926EJ-S
    --cpu=ARM946E-S
    --cpu=ARM966E-S
    --cpu=Cortex-M0
    --cpu=Cortex-M0plus
    --cpu=SC000
    --cpu=Cortex-M1
    --cpu=Cortex-M1.os_extension
    --cpu=Cortex-M1.no_os_extension
    --cpu=Cortex-M3
    --cpu=Cortex-M3-rev0
    --cpu=SC300
    --cpu=Cortex-M4
    --cpu=Cortex-M4.fp.sp
    --cpu=Cortex-M7
    --cpu=Cortex-M7.fp.sp
    --cpu=Cortex-M7.fp.dp
    --cpu=Cortex-R4
    --cpu=Cortex-R4F
