Ethernet Initialization Hangs When Hardware Is Not Present
We are using an LPC4088 microcontroller with an Ethernet PHY (LAN8720) connected via RMII interface. The software stack includes MDK middleware version 7.12.0 and DFP version 2.2.2. The PHY is located on an Ethernet plug-in board.
When we call the netInitialize() function:
If the plug-in board is connected: netInitialize() returns success and Ethernet works as expected.
If the plug-in board is NOT connected: The code hangs inside netInitialize() and does not return.
Issue: We need a way to prevent the system from hanging when the Ethernet hardware is not present. Ideally, netInitialize() should return an error code or timeout instead of blocking indefinitely.
Questions:
1. Is there a recommended approach to handle missing Ethernet hardware in MDK middleware?
2. Can we configure a timeout or detect PHY presence before calling netInitialize()?
3. Are there any known fixes or patches for this behavior in version 7.12.0?
  • In an RMII interface, the PHY provides the clock for the EMAC peripheral. The netInitialize function does not contain an endless loop when the PHY is being initialized, so it is expected to return even in the event of a PHY error. However, the EMAC never exits its soft-reset state when the PHY is powered down or missing, because the required 50 MHz clock is not available. As a result, the software likely ends up in a hard fault exception caused by the missing clock.
    A practical solution is to verify the presence of the plug-in board before calling netInitialize. This can be done by reading an I/O pin—if available—that is connected to the plug-in board and indicates whether it is present.
  • Thanks for your response.
    We already verify the presence of the plug-in board before invoking netInitialize(), which indicates whether the board is present or not. However, we also have some PCBs where the Ethernet hardware is integrated directly on the board without a plug-in module. For these cases, we are looking for a software-based solution that can reliably return an error if the Ethernet hardware is missing or if there is a hardware-related issue.
  • You can use the bit-banding routines that implement MDIO communication by manually toggling the port pins in software. This avoids accessing the EMAC peripheral and therefore prevents any hard-fault exceptions it might generate.
    The necessary functions are available in the EMAC_LPC17xx.c Ethernet driver for LPC17xx devices. Try reading the REG_PHYIDR1 register at address 0x2; the expected value is 0x0007.
    If the read operation returns 0x0007, then the PHY is present and it is safe for the software to call netInitialize(). If not, netInitialize() should not be invoked.
