This code cannot be compiled
#include "reg51.h"
void main(void) {
	P1 = 0x00;
	int a = 0;
This code cannot be compiled("1.c(5): error C141: syntax error near 'int', expected '__asm'").
  • But this can be compiled:
    #include "reg51.h"
    void main(void) {
    	int a = 0;
  • And these can be compiled too:
    #include "reg51.h"
    void main(void) {
    	P1 = 0x00;
    #include "reg51.h"
    void main(void) {
    	int a = 0;
    	P1 = 0x00;
  • The C51 compiler basically supports the old ANSI C standard C90 with some extensions for the 8051 architecture.
    The C90 standard does not allow defining local variables after executable statements within a function. In C90, the syntax rules require that all declarations within a block must come before any statements.
    "P1 = 0x00;" is a statement that generates code, because P1 is already defined. After that, no definition of a local variable is allowed.
    The C99 standard would allow to intermix statements and definitions, but the C51 compiler will never support this standard.
