s32k144 example for blinky code is not compiling
When i tried to build the example project form S32_SDK_DFP got errors as mentioned below.
Error instantiating RTE components
Error #540: 'Board Support:A/D Converter(API)@1.0.0' API is not available for target 'Debug'
Error #540: 'Board Support:Buttons(API)@1.0.0' API is not available for target 'Debug'
Error #540: 'Board Support:LED(API)@1.0.0' API is not available for target 'Debug'
Error #542: Component 'Keil::Board Support&S32K144-EVB:A/D Converter@1.0.0': API version '1.0.0' or compatible is required.API definition is missing (no pack ID is available)
Error #542: Component 'Keil::Board Support&S32K144-EVB:Buttons@1.0.0': API version '1.0.0' or compatible is required.API definition is missing (no pack ID is available)
Error #542: Component 'Keil::Board Support&S32K144-EVB:LED@1.0.0': API version '1.0.0' or compatible is required.API definition is missing (no pack ID is available)
Default path for blinky: C:\Arm\Packs\Keil\S32_SDK_DFP\1.5.1\MDK\Boards\NXP\S32K144-EVB\RTOS2_KeilRTX5_Blinky
Expectation: example code as to be build without error.
Please support how to solve this error.
