Keil is creating an unwanted out file
I'm using uVision 5.41.
I'm creating a new project, select uC STM32H723, Packs: none selected. Add a simple main.c and a init file (tried a C init and a .s init, both same result).
Compile the project. Got the error:
Build target 'Target_1'
FCARM - Output Name not specified, please check 'Options for Target - Utilities'
Go to Options for target -> Utilities tab -> put a name for FCARM "project_out"
Then Keil is creating a huge "project_out" file with a lot of trash that I don't want to have, and it generates a lot of errors in the compilation.
Starting of the created file:
* Generated by FCARM FILE CONVERTER V2.59
* Name: project_out
* Purpose: HTTP Web page, generated by the user.
* Note: This is a generated file, do not modify !!!
* This code is part of the RealView Run-Time Library.
* Copyright (C) 2015-2022 ARM Ltd and ARM Germany GmbH. All rights reserved.
#include <Net_Config.h>
/* Last-Modified: Mon, 08 Sep 2025 12:57:45 GMT */
const U32 FileMD = 1757336265U;
static const U8 Web[25234U] = {
/*-- File: Sources\startup_stm32h743xx.c, 25086 bytes --*/
0x2FU,0x2AU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,
0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,0x3DU,
0x3DU,0x3DU,0x0AU,0x20U,0x4EU,0x61U,0x6DU,0x65U,0x20U,0x20U,0x20U,0x20U,0x20U,
I have a simple board with the uC, without any wi-fi, and I don't want it. I just want to run a simple main.c to flash a LED.
How to solve this?
  • I have no idea why FCARM is invoked in your project. Usually, you need to set this up manually. FCARM is used to create a kind of compiled filesystem which can be used for example for web-pages for a HTTP-server. You must have defined an 'Output File', an 'Output Group' and 'Image Files Root Folder' in the dialog 'Options for Target - Utilities - Configure Image File Processing (FCARM)' to activate the FCARM tool.
    You just need to add your source file into the Project window to build your project. Please set up your project again or use one of the predefined projects from one of the packs.
  • Hello Hans,
    Thank you for answering.
    After some hours working on it, I found the reason.
    I had a folder named "Sources" where I put the sources - .c files.
    I just renamed it to "src" and the issue disappeared.
    It seems Keil looks for a specific folder named "Sources" for something.
    Regards,
    Ricardo
