Since I updated keil uvision V5.38 to V5.42, I have in build output tab a message about run time environment :
Validate Run Time Environment: errors/warnings detected:'Keil::Network&MDK-Pro:Socket:TCP@7.18.0': warning #515: Additional software components required require CMSIS:CORE@5.0.1: Select component from list 'ARM::CMSIS:CORE' accept Network&MDK-Pro:CORE: Select component from list 'Keil::Network&MDK-Pro:CORE''Keil::Network&MDK-Pro:Service:Web Server&HTTP@7.18.0': warning #515: Additional software components required require CMSIS:CORE@5.0.1: Select component from list 'ARM::CMSIS:CORE' accept Network&MDK-Pro:CORE: Select component from list
Do you know how to remove this message ?
