STM32U5 USB Driver runs in Timeout in soft reset
I use a STM32U5 and the Keil V8.0.0 USB and MSC driver.
But during initalisation I run in a Timeout in the stm32u5xx_ll_usb.c file at USB_CoreReset for the Core Soft Reset.
I use it as host only in full speed, configuration done in CubeMX.
The clock couldn't be configured to 48MHz as writen in the driver head in USBH_STM32.c.
I add the Handle from the usb_otg.c file to the MX_Device.h file
#define MX_USB_OTG_HS_HANDLE hhcd_USB_OTG_HS
Thanks and kind regards
René
Code with Timeout in stm32u5xx_ll_usb.c
static HAL_StatusTypeDef USB_CoreReset(USB_OTG_GlobalTypeDef *USBx)
__IO uint32_t count = 0U;
/* Wait for AHB master IDLE state. */
do
count++;
if (count > HAL_USB_TIMEOUT)
return HAL_TIMEOUT;
} while ((USBx->GRSTCTL & USB_OTG_GRSTCTL_AHBIDL) == 0U);
/* Core Soft Reset */
count = 0U;
USBx->GRSTCTL |= USB_OTG_GRSTCTL_CSRST;
do
count++;
return HAL_TIMEOUT; <============ run into this timeout
} while ((USBx->GRSTCTL & USB_OTG_GRSTCTL_CSRST) == USB_OTG_GRSTCTL_CSRST);
return HAL_OK;
