Ethernet is not available on NUCLEO-H753ZI (using Keil RTX5)
I cannot connect Ethernet in Keil µVision V5.42 and NUCLEO-H753ZI.
There is no response for ARP or Ping.
How do I connect NUCLEO-H753ZI to a PC via Ethernet in Keil RTX5?
Have I forgotten to configure something?
This environment is as follows.
Board : NUCLEO-H753ZI (CPU:STM32H753ZI)
IDE : µVision V5.42.0.0
Compiler : ARM Compiler v6
RTOS : Keil RTX5
Others : STM32CubeMX Ver.6.15.0
I have done as follows:
1. µVision Pack Install
ARM::CMSIS ver.6.2.0
ARM::CMSIS-Driver ver.2.10.0
ARM::CMSIS-Driver_STM32 ver.1.2.0
ARM::CMSIS-RTX ver.5.9.0
Keil::MDK-Middleware ver.8.1.0
Keil::STM32H7xx_DFP ver.4.1.0
2. µVision RTE
"CMSIS -> CORE (ver.6.1.1)" Enabled
"CMSIS -> RTOS2 (API) -> Keil RTX5 (ver.5.9.0)" Enabled
"CMSIS Driver -> Ehternet MAC (API) -> Ethernet MAC (ver.3.1.0)" Enabled
"CMSIS Driver -> Ehternet PHY (API) -> LAN8742A (ver.1.3.0)" Enabled
"Device -> CobeMX (Ver.1.0.0)" Enabled (For details, see Chapter 3,4,5. STM32CubeMX)
"Network -> CORE (ver.8.1.0)" Enabled
"Network -> Interface -> ETH" to 1
"Network -> Socket -> TCP" Enabled
"Network -> Socket -> UDP" Enabled
3. STM32CubeMX  "Pinout & Configuration" Tab
"Connectivity -> ETH"
"Mode" to RMII
"GPIO Settings"
PA1 ETH_REF_CLK
PA2 ETH_MDIO
PA7 ETH_CRS_DV
PB13 ETH_TXD1
PC1 ETH_MDC
PC4 ETH_RXD0
PC5 ETH_RXD1
PG11 ETH_TX_EN (Not default)
PG13 ETH_TXD0 (Not default)
"Parameters Settings" (by default)
Ethernet MAC Address : 00:80:E1:00:00:00
Tx Descriptor Length : 4
First Tx Descriptor Address : 0x30000080
Rx Descriptor Length : 4
First RX Descriptor Address : 0x30000000
Rx Buffers Address : 0x30000100
Rx Buffers Length : 1536
"NVIC Settings"
Ethernet global interrupt : Enabled
"System Core -> CORETEX_M7"
MPU Control Mode : MPU NOT USED
"System Core -> GPIO"
Maximum output speed : I set Maximum output speed of All GPIO to High.
"System Core -> NVIC -> Code generation"
System service call via SWI instruction : Generate IRQ handler : Disabled
Pendable request for system service : Generate IRQ handler : Disabled
Time base : System tick timer : Generate IRQ handler : Disabled
4. STM32CubeMX  "Clock Configuration" Tab
"To CPU Clocks (MHz)/ To CPU Systick Clock (MHz)" is 400MHz.
Peripheral clocks is 200MHz or 100MHz.
5. STM32CubeMX  "Project Manager" Tab
"Project" Tab
Toolchain/IDE to MDK-ARM, Min Version to V5.32
6. Do "GENERATE CODE"
7. RTX Configuration (RTX_Config.h)
"Thread Configuration -> Default Thread Stack size [bytes]" to 4096 (4K)
Others are default.
8. Net Configuration (Net_Config.h)
"Network Core -> Variant" to IPv4 only
Others are default.
9. Net(ETH0) Configuration (Net_Config_ETH_0.h)
"Ethernet Network Interface 0 -> Dynamic Host Configuration" Disabled
"Ethernet Network Interface 0 -> Dynamic Host IPv6" Disabled
Others are default.
ETH0 is ip address 192.168.0.100, mask 255.255.255.0, gateway 192.168.0.254.
10. Option for Target
"Option for Target -> C/C++ (AC6) -> Language C" to C11
"Option for Target -> C/C++ (AC6) -> Short enums/wchar" Disabled
"Option for Target -> Linker -> Use Memory Layout from Target Dialog" Disabled
Modify Scatter File.
LR_IROM1 0x08000000 0x00100000 { ; load region size_region
  ER_IROM1 0x08000000 0x00100000 { ; load address = execution address
    *.o (RESET, +First)
    *(InRoot$$Sections)
    .ANY (+RO)
    .ANY (+XO)
  RW_IRAM2 0x24000000 0x00080000 { ; RW data
    .ANY (+RW +ZI)
  RW_DMARxDscrTab 0x30000000 0x00000080 { ; RW data
    *(.RxDescripSection)
  RW_DMATxDscrTab 0x30000080 0x00000080 { ; RW data
    *(.TxDescripSection)
  RW_Rx_Buff 0x30000100 0x00000F00 { ; RW data
    *(.RxArraySection)
"Option for Target -> Debug -> Use" To ST-Link Debugger
11. Add code in Main.c
Add Includes
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "cmsis_os2.h"
#include "rl_net.h"
/* USER CODE END Includes */
Add USER CODE 2
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_ETH_Init();
/* USER CODE BEGIN 2 */
SystemCoreClockUpdate();
osKernelInitialize();
netInitialize();
osKernelStart();
/* USER CODE END 2 */
12. Setup Windows PC
ip address 192.168.0.10, mask 255.255.255.0, gateway {empty}
In this environment, when I send "arp -a" or "ping 192.168.0.100" from a Windows PC, I get no response...
