Placing variables in different memory section in keil v5( arm compiler 6)
HI
I want to place:
  • All static variables into a custom RAM section (e.g., .my_data)
  • All code, including static functions and global functions, into a custom code section (e.g., .my_text) using memory mapping concept of AUTOSAR
These is my source file code (.c):
#define START_SEC_VAR
#include "MemMap.h"
static uint8_t counter1 ;
static uint8_t counter2;
#define STOP_SEC_VAR
#include "MemMap.h"
#define START_SEC_CODE
#include "MemMap.h"
/* Static function */
static void countInc(void)
counter1++;
counter2++;
/* Global function */
void Process(void)
countInc();
#define STOP_SEC_CODE
#include "MemMap.h"
This is MemMap.h file(.h):
#ifdef START_SEC_VAR
#undef START_SEC_VAR
#pragma section ".my_data"
#endif
#ifdef STOP_SEC_VAR
#undef STOP_SEC_VAR
#endif
#ifdef START_SEC_CODE
#undef START_SEC_CODE
#pragma section ".my_text"
#endif
#ifdef STOP_SEC_CODE
#undef STOP_SEC_CODE
#endif
Constraints:
  • I do not want to modify the .c files.
  • I’m using Keil v5 with ARM Compiler 6, so #pragma arm section is not supported. I need to make changes in MemMap.h file only.
  • I had also tried with
    __attribute__((section(""))) too, it was compiled but the variables not at the specified memory section.
What i tried:
  • Used .ANY in .sct, then replaced with *(.my_data) but still got no match warning.
  • Verified that static variables and functions work fine in their default sections.
Let me know if any further details are required.
