ARM Development Studio IDE: Error C9555E when trying to compile with ARM Compiler 5.06.6
Dear ARM Support Team,
   after several tries I would need your support.
I am currently experiencing an issue with ARM Development Studio IDE Version: 2024.1 Build: 202410918, of which I purchased a license:
I have the need to compile a project created with MDK 5.30 and ARM Compiler 5.06 update 6.
Therefore I downloaded and installed the ARM Compiler 5.06 update 6 in the same folder of Development Studio:
Then registered the compiler:
And finally imported the uVision project with correct compiler, but when I try to build I get the following:
7:56:46 **** Build of configuration Debug for project MR88FX02_BSP_Target_1 ****
make all
'Building file: ../Cycle/CheckSheet.c'
'Invoking: Arm C Compiler for Embedded 5.6.6'
armcc.exe --cpu=Cortex-M0 --littleend -DCHIP_SELECT="MR88FX02" -D_RTE_ -DMR88Fx02 -I"C:\Users\xxxxxx\Documents\ARM\Development Studio Workspace\MR88FX02_BSP_Target_1/BaseBoard" -I"C:\Users\xxxxxx\Documents\ARM\Development Studio Workspace\MR88FX02_BSP_Target_1/MR88F002CI_7601S" -I"C:\Users\xxxxxx\Documents\ARM\Development Studio Workspace\MR88FX02_BSP_Target_1/MR_Wifi" -I"C:\Users\xxxxxx\Documents\ARM\Development Studio Workspace\MR88FX02_BSP_Target_1/MainProgramme" -I"C:\Users\xxxxxx\Documents\ARM\Development Studio Workspace\MR88FX02_BSP_Target_1/Cycle" -I"C:/Users/xxxxxx/AppData/Local/Arm/Packs/ARM/CMSIS/6.1.0/CMSIS/Core/Include" -I"C:/Users/xxxxxx/AppData/Local/Arm/Packs/MRSEMI/MR88Fx02/1.0.12/Device/Include" -I"C:\Users\xxxxxx\Documents\ARM\Development Studio Workspace\MR88FX02_BSP_Target_1/RTE" -I"C:\Users\xxxxxx\Documents\ARM\Development Studio Workspace\MR88FX02_BSP_Target_1/RTE/Device/MR88FX02CI" --c99 -O2 -g --diag_suppress=177 --diag_suppress=513 --diag_suppress=550 --diag_suppress=1295 --split_sections --md --depend_format=unix_escaped --no_depend_system_headers --depend_dir="Cycle" -c -o "Cycle/CheckSheet.o" "../Cycle/CheckSheet.c"
Error: C9555E: Failed to check out a license.
The license file could not be found. Check that ARMLMD_LICENSE_FILE is set correctly.
Information about this error is available at: ds.arm.com/.../m1
General licensing information is available at: ds.arm.com/.../
If you need further help, provide this complete error report to your supplier or license.support@arm.com.
- ARMLMD_LICENSE_FILE: 'C:\Users\xxxxxx\AppData\Roaming\arm\ds\licenses'
- LM_LICENSE_FILE: unset
- ARM_TOOL_VARIANT: unset
- ARM_PRODUCT_PATH: unset
- Product location: C:\Program Files\Arm\Development Studio 2024.1\sw\ARM_Compiler_5.06u6\sw\mappings
- Toolchain location: C:\Program Files\Arm\Development Studio 2024.1\sw\ARM_Compiler_5.06u6\bin
- Selected tool variant: product
- Checkout feature: compiler5
- Feature version: 5.0201709
- Flex error code: -1
Product: ARM Compiler 5.06
Component: ARM Compiler 5.06 update 6 (build 750)
Tool: armcc [4d3637]
make[1]: *** [Cycle/subdir.mk:20: Cycle/CheckSheet.o] Error 1
make: *** [makefile:59: all] Error 2
"make all" terminated with exit code 2. Build might be incomplete.
07:56:47 Build Failed. 3 errors, 0 warnings. (took 995ms)
Moreover when I create a diagnotic report from the license management utility I get the following info in the JSON:
"OperatingSystem": "windows/amd64",
 "SetupErrors": [],
 "EnvironmentVariables": [],
 "LegacyLicensing": {
  "EnvVars": [
    "Name": "ARMLMD_LICENSE_FILE",
    "Value": "C:\\Users\\xxxxxx\\AppData\\Roaming\\arm\\ds\\licenses"
  "FlexlmrcContent": ""
But the folder license does not exist in such path in my PC (it stops at ds folder):
I have no clue how to proceed. I really need your help.
Thank you for your assistance.
0
