#include "lora.h" #include "stm32f10x_spi.h" // Keil::Device:StdPeriph Drivers:SPI #include <string.h> #include <stdio.h> #include "delay.h" #define SPI1_NSS GPIO_Pin_4 #define SPI1_SCK GPIO_Pin_5 #define SPI1_MISO GPIO_Pin_6 #define SPI1_MOSI GPIO_Pin_7 #define SPI1_RESET GPIO_Pin_0 #define RESET_PORT GPIOB #define SPI1_GPIO GPIOA void SPI_Config(void){ GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin =SPI1_SCK| SPI1_MISO| SPI1_MOSI|SPI1_NSS|SPI1_RESET; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //Chan hoat dong trong 1 chuc nang thay the nhu I2C, SPI GPIO_Init(SPI1_GPIO, &GPIO_InitStructure); GPIO_WriteBit(SPI1_GPIO, SPI1_NSS, Bit_SET); //SPI Config SPI_InitTypeDef SPI_InitStruct; SPI_InitStruct.SPI_Mode = SPI_Mode_Master; //Chon kieu thiet bi master hay slave SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //Quy dinh kieu truyen Song cong, Ban song cong, don cong SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64; //Chia tan so xung Clock. Tan so mac dinh 72MHZ SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low; // Khi k cap xung thi SCK = 0 SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge; //Tin hieu truyen di o canh xung dau tien SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;//Truyen 8bit hoac 16bit SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB; // Truyen bit trong so cao truoc SPI_InitStruct.SPI_CRCPolynomial = 10 ;//Cau hinh Checksum, neu Data8bit thi de 7, neu 16bit thi de 15, co the de mac dinh SPI_InitStruct.SPI_NSS = SPI_NSS_Soft; //Cau hinh che do chan CS dc quan ly boi Sorfware (1 bit SSI) hay Hardware (1 Pin NSS) SPI_Init(SPI1, &SPI_InitStruct); SPI_Cmd(SPI1,ENABLE); } uint8_t transmitData(uint8_t data) { while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE)==RESET); SPI_I2S_SendData(SPI1,data); while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE)==RESET); return (uint8_t)SPI_I2S_ReceiveData(SPI1); } void lora_write_reg(uint8_t addr, uint8_t cmd) { uint8_t add = addr | 0x80; // Ð?t bit cao d? ghi GPIO_WriteBit(SPI1_GPIO, SPI1_NSS, Bit_RESET); // Kích ho?t NSS delay_ms(1); // G?i d?a ch? thanh ghi transmitData(add); while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET); transmitData(cmd); while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY)==SET); GPIO_WriteBit(SPI1_GPIO, SPI1_NSS, Bit_SET); // H?y kích ho?t NSS delay_ms(1); } uint8_t lora_read_reg(uint8_t addr) { uint8_t txByte = addr & 0x7F; uint8_t rxByte = 0x00; GPIO_WriteBit(SPI1_GPIO, SPI1_NSS, Bit_RESET); delay_ms(1); rxByte = transmitData(txByte); rxByte = transmitData(0xFF); //rxByte = transmitData(); while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY)==SET); GPIO_WriteBit(SPI1_GPIO, SPI1_NSS, Bit_SET); delay_ms(1); return rxByte; // } uint8_t ret;//, ret1, ret2, ret3, ret4,ret5; uint8_t lora_init(void) { GPIO_WriteBit(RESET_PORT, SPI1_RESET, Bit_RESET); delay_ms(10); GPIO_WriteBit(RESET_PORT, SPI1_RESET, Bit_SET); delay_ms(10); ret = lora_read_reg(REG_VERSION); if (ret != 0x12) { return 1; } lora_write_reg(REG_OP_MODE, (MODE_LONG_RANGE_MODE | MODE_SLEEP)); lora_set_frequency(FREQUENCY[0]); lora_write_reg(REG_FIFO_TX_BASE_ADDR, 0); //ret1 = lora_read_reg(REG_FIFO_TX_BASE_ADDR); lora_write_reg(REG_FIFO_RX_BASE_ADDR, 0); //ret2 = lora_read_reg(REG_FIFO_RX_BASE_ADDR); ret = lora_read_reg(REG_LNA); lora_write_reg(REG_LNA, ret | 0x03); lora_write_reg(REG_MODEM_CONFIG_3, 0x04); //ret3 = lora_read_reg(REG_MODEM_CONFIG_3); lora_write_reg(REG_PA_CONFIG, 0x8f); //ret4 = lora_read_reg(REG_PA_CONFIG); lora_write_reg(REG_OP_MODE, (MODE_LONG_RANGE_MODE | MODE_STDBY)); //ret5 = lora_read_reg(REG_PA_CONFIG); return 0; } //uint8_t f1,f2,f3; void lora_set_frequency(uint64_t freq){ uint64_t frf = ((uint64_t)freq << 19) / 32000000; lora_write_reg(REG_FRF_MSB, (uint8_t)(frf >> 16)); lora_write_reg(REG_FRF_MID, (uint8_t)(frf >> 8)); lora_write_reg(REG_FRF_LSB, (uint8_t)(frf >> 0)); //f1 = lora_read_reg(REG_FRF_MSB); //f2 = lora_read_reg(REG_FRF_MID); //f3 = lora_read_reg(REG_FRF_LSB); } uint8_t lora_begin_packet(void) { ret=lora_read_reg(REG_OP_MODE); if ((lora_read_reg(REG_OP_MODE) & MODE_TX) == MODE_TX) { return 1; } lora_write_reg(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_STDBY); lora_write_reg(REG_MODEM_CONFIG_1, 0x72); lora_write_reg(REG_FIFO_ADDR_PTR, 0); lora_write_reg(REG_PAYLOAD_LENGTH, 0); return 0; } uint8_t lora_tx(uint8_t * buf, uint8_t size) { int currentLength = lora_read_reg(REG_PAYLOAD_LENGTH); if ((currentLength + size > MAX_PKT_LENGTH)) { size = MAX_PKT_LENGTH - currentLength; } for (int i = 0; i < size; i++) { lora_write_reg(REG_FIFO, buf[i]); } lora_write_reg(REG_PAYLOAD_LENGTH, currentLength + size); return 0; } uint8_t lora_end_packet(void) { uint8_t timeout = 100; lora_write_reg(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_TX); while ((lora_read_reg(REG_IRQ_FLAGS) & IRQ_TX_DONE_MASK) == 0) { if (--timeout == 0) { delay_ms(1); return 1; } } lora_write_reg(REG_IRQ_FLAGS, IRQ_TX_DONE_MASK); return 0; }
Hi there, I have moved your question to the Keil forum. If this is incorrect please let me know by replying to this comment. Thanks.
