I want to check memory usage for the consideration of a microcontroller to be used in an embedded system.Is there a way to check this?
Development environment used: keil studio
Static values are given at link time (--info totals), or can be determined from the executable (fromelf -z).
Dynamic usage (stack, heap) depends on the application. The below apps note goes into some detail:
https://developer.arm.com/documentation/kan316/
Sorry for my ignorance.Is it possible to do that operation in keil studio cloud?
The linker generated values should be output at the end of a build.
The more advanced debug features (notably RTX awareness) of uVision are not yet supported in the KSC environment.
"The linker generated values should be output at the end of a build."does this mean the following that appears in Output?Flash: ** KB / ** KBMemory: ** KB / ** KBROM: ** KB / ** KB
On Nucleo-F302R8 the Memory value seems to be correct, but when I change from the complex code to the following simple code on Nucleo-G431RB, the Memory value does not change from 32 KB.
---#include "mbed.h"
Note that when I tried the following on Nucleo-F302R8, Memory was 1KB.---#include "mbed.h"
What is the difference between the two?
Also, is there any way to know the correct Memory value in Nucleo-G431RB?
Can you run "fromelf -z" on the generated ELF (not binary) image?
When I build with keil studio online, does it also generate an ELF file?It only generates a binary file.If I am wrong about how to generate ELF files, please let me know.
I may be wrong (I am not familiar with mbed), but the linker generates ELF images which are converted into binary, so there must be one?
