in my project I am try to jump 0x8002000 address . but I am facing some failure,
int main(void){/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */MX_GPIO_Init();/* USER CODE BEGIN 2 *///myFunction();jumpToAddress(0x8002000);
/* USER CODE END 2 */
/* Infinite loop *//* USER CODE BEGIN WHILE */while (1){/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */}/* USER CODE END 3 */}
this is my main function.
this image is my .map file for my project.
I am try to jump 0x8002000 address my project shown ,
this output. so kindly help to me.
thanks
It is very difficult to follow the code above.
I don't understand why you have relocated the vector table based on the jump address?
SCB->VTOR = address;
You should step through the code at a disassembly level to understand how the code gets to the 0x22006012 address.
