Hi there,
I am taking a lot time to try creating an FLM to program some date to the FMC Nand-Flash on my homemade board.
I already read This Tutorial and this This page, but I am NOT successful.
My MCU is STM32F429BIT6 and my Nand-Flash is H27U1G8F2BTR, I already have a demo to read/write/erase the Flash normally by HAL lib.
The Nand-Flash is 2KBytes * 64Pages * 1024Blocks = 128MBytes, so I config as this:
struct FlashDevice const FlashDevice = { FLASH_DRV_VERS, // Driver Version, do not modify! "ARMFLY_STM32V6_NandFlash", // Device Name EXT8BIT, // Device Type 0x70000000, // Device Start Address 0x08000000, // Device Size in Bytes (128MB) 2048, // Programming Page Size 0, // Reserved, must be 0 0xFF, // Initial Content of Erased Memory 6000, // Program Page Timeout 100 mSec 6000, // Erase Sector Timeout 3000 mSec // Specify Size and Address of Sectors 0x020000, 0x000000, // Sector Size 128kB (1024 Sectors) SECTOR_END };
and finished FlashPrg.c as below:
#define DEV_ADDR 0x70000000 #define PAGE_SIZE 2048 #define BLOCK_NUM 1024 #define BLOCK_SIZE (2048 * 64) int Init (unsigned long adr, unsigned long clk, unsigned long fnc) { HAL_Init(); SystemClock_Config(); MX_GPIO_Init(); MX_FMC_Init(); return (0); // Finished without Errors } int EraseSector (unsigned long adr) { adr -= DEV_ADDR; NAND_AddressTypeDef nand_addr = {.Page = 0, .Block = adr / BLOCK_SIZE, .Plane = 0}; if(HAL_NAND_Erase_Block(&hnand1, &nand_addr)) { return 1; } return (0); // Finished without Errors } int ProgramPage (unsigned long adr, unsigned long sz, unsigned char *buf) { adr -= DEV_ADDR; NAND_AddressTypeDef nand_addr = {.Page = adr % BLOCK_SIZE / PAGE_SIZE, .Block = adr / BLOCK_SIZE, .Plane = 0}; if(HAL_NAND_Write_Page_8b(&hnand1, &nand_addr, buf, 1)) { return 1; } return (0); // Finished without Errors }
Of cause I rewrite the HAL_GetTick(), HAL_Delay(), and HAL_Inc() functions the same as the tutorial.
But when I load the FLM and try to program the Nand-Flash, the IDE always Programming Failed!
What‘s wrong with my FLM and How to fix it?
Thands to your help!
