I am using this version of Kiel
When a folder is created on SD CARD it always shows up with upper case letters.
I was wondering if there is a way to create a folder with lower case letters.
Are you using the LFN (long filename) or SFN (short filename) library?
SFN will store names in uppercase.
Btw, as a registered user you are entitled to open a Support Ticker for a closer investigation:
https://www.arm.com/support/contact-support
From CubeMX I can confirm LFN is enabled
Thanks rkopsch,All short name entries meaning 8 or less characters for file name, 3 or less characters for file extension are encoded with upper case characters, Windows uses reserved bit to hold information if all letters were upper case or lower case, thus it deviates from FAT specification, and this feature is not supported by FlashFS.Seems like folder i create less then 8 character is Upper case however longer folders are not case sensitive.
