I am using uVision V5.39.0.0 and Pack Installer V1.4.0.49 for a Nordic Semi nRF52832 project. I have installed all of the packs for the nRF52832 but am missing a pack or packs according to the following Build Output:
Validate Run Time Environment: errors/warnings detected:'NordicSemiconductor::nRF_BLE:BLE_Modules:ble_advertising@4.0.0-2.alpha': warning #515: Additional software components required require NordicSemiconductor::nRF_Libraries:app_trace@4.0.0-2.alpha: Select component from list
'NordicSemiconductor::nRF_Libraries:app_trace''NordicSemiconductor::nRF_BLE:BLE_Modules:device_manager&Peripheral@4.0.0-2.alpha': warning #515: Additional software components required require NordicSemiconductor::nRF_Libraries:app_trace@4.0.0-2.alpha: Select component from list 'NordicSemiconductor::nRF_Libraries:app_trace''NordicSemiconductor::nRF_Libraries:nrf_log&default@4.0.0-2.alpha': warning #515: Additional software components required accept NordicSemiconductor::Board Support:bsp@11.0.0-2.alpha: Select component from list 'NordicSemiconductor::Board Support:bsp' require NordicSemiconductor::nRF_Drivers:app_uart@4.0.0-2.alpha: Select component from list 'NordicSemiconductor::nRF_Drivers:app_uart' require NordicSemiconductor::nRF_Libraries:retarget@4.0.0-2.alpha: Select component from list 'NordicSemiconductor::nRF_Libraries:retarget'
Where do I find the packs for the missing software components?
Hello Bruce,
At first glance, If you want to build a project using these older packs, I suggest following the steps in this application note:developer.arm.com/.../
To get the latest packs, Keil MDK projects offered inside the nRF5 SDK. This kit includes a wide variety of examples for both the nRF51 and nRF52 device families, and is the preferred delivery method of Keil MDK examples developed by Nordic. See developer.arm.com/.../latest
See also:
