Flash Download failed for NUCLEO-F429ZI board
Trying to run the program for NUCLEO-F429ZI STM evaluation board, I get "No Algorithm found" error:
Build started: Project: test_f429zi
*** Using Compiler 'V6.21', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'
Build target 'test_f429zi'
".\test_f429zi.axf" - 0 Error(s), 0 Warning(s).
Build Time Elapsed:  00:00:00
Load "C:\\Alex\\projects\\STM\\Keil\\NUCLEO-F429ZI\\test_f429zi\\test_f429zi\\MDK-ARM\\test_f429zi.axf"
No Algorithm found for: 00008000H - 00008F77H
Erase skipped!
Error: Flash Download failed  -  "Cortex-M4"
Flash Load finished at 09:20:33
The project is created in STM32 CubeMX, code is generated in MDK format, as described here: Using Keil MDK with STM32CubeIDE
My working environment: Windows 11, mVision v5.39.0.0 Community Edition, NUCLEO-F429ZI evaluation board.
The same board can be successfully programmed using STM32CubeIDE:
STMicroelectronics ST-LINK GDB server. Version 7.5.0
Copyright (c) 2023, STMicroelectronics. All rights reserved.
Starting server with the following options:
        Persistent Mode            : Disabled
        Logging Level              : 1
        Listen Port Number         : 61234
        Status Refresh Delay       : 15s
        Verbose Mode               : Disabled
        SWD Debug                  : Enabled
        InitWhile                  : Enabled
Waiting for debugger connection...
Debugger connected
Debugger connected
                       STM32CubeProgrammer v2.15.0
Log output file:   C:\Users\alex\AppData\Local\Temp\STM32CubeProgrammer_a12284.log
ST-LINK SN  : 066DFF484957847167063817
ST-LINK FW  : V2J43M28
Board       : NUCLEO-F429ZI
Voltage     : 3.25V
SWD freq    : 4000 KHz
Connect mode: Under Reset
Reset mode  : Hardware reset
Device ID   : 0x419
Revision ID : Rev 3
Device name : STM32F42xxx/F43xxx
Flash size  : 2 MBytes
Device type : MCU
Device CPU  : Cortex-M4
BL Version  : 0x91
Memory Programming ...
Opening and parsing file: ST-LINK_GDB_server_a12284.srec
  File          : ST-LINK_GDB_server_a12284.srec
  Address       : 0x08000000
Erasing memory corresponding to segment 0:
Erasing internal memory sectors [0 4]
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:02.441
Verifying ...
Download verified successfully
Shutting down...
Exit.
MDK debugger settings:
  • Hi Alex,
    by your log on the first screenshot you are trying to program code at address 0x00008000 and flash on this MCU is located at address 0x08000000, so the algorithm is not able to program the code at 0x00008000 address.
    Flash from 0x08000000 can be re-mapped to address 0 but the code should still be programmed to 0x08000000.
    Maybe for start you take an example from https://www.keil.com/pack/Keil.STM32F4xx_DFP.2.17.1.pack, there is example in the folder MDK\Boards\ST\STM32F429I-Discovery\Blinky which works for STM32F429I-Discovery board and you can continue from there.
    Best regards, Milorad
  • Thanks. I downloaded Blinky sample from NUCLEO-F429ZI
    It started from Keil uVision without any changes. Comparing the settings for two projects, I made the following changes in my CubeMX-based project:
    Options for Target.
    Linker tab.
    Use Memory Layout from Target Dialog - checked.
    Target tab.
    IROM1, IRAM1 - checked.
    The problem is solved.
