Not Building or Even Generating Errors
I cut and paste a PWM project from the internet and saved it. When I go to build it, I got neither messages indicating success or errors or warnings. It just kind of hangs there. Here's a screen shot.
  • µVision does not hang there, it completed the build job. Your project does not contain any source code and therefore µVision did nothing when you started a project build.
  • Thanks I'm obviously struggling with Keil. I can't seem to troubleshoot these problems. If I may trespass on your generosity, can you tell me what you did in terms of analyzing this error ? Like the old "Give a man a fish " cliché, I'd like to learn how to trouble shoot these errors caused by project environment errors.
  • Here is yet another error that I can't figure out. It just keeps going on like that. I downloaded the Blinky program from the examples and had run it before. This time i get these cryptic errors that I can find little about online.
  • >If I may trespass on your generosity, can you tell me what you did in terms of analyzing this error ?
    Your 'Source Group 1' in the project window (left-hand side) is empty and the 'Build Output' window does not list any modules that get compiled.
  • I don't know what you are doing. The picture is hard to read and I can't magnify it like your previous picture. The first error message is:
    ArmClang: error: unsupported option '--c99'
    --c99 is a armcc (Arm Compiler 5) compatible compiler directive. You are using the ArmClang (Arm Compiler 6) and the directive should read '-std=c99'. Usually, µVision automatically uses the right directive depending on the selected compiler. I assume that --c99 is specified in the µVision dialog 'Options for Target - C/C++ (AC6) - Misc Controls'. If yes, remove it from there and select c99 in the 'Language C' selection.
    The second error '… Assembler.… Symbol missing..' probably comes from a wrong assembler directive. Please check the µVision dialog 'Options for Target - Asm - Assembler Option' and select 'armclang (Auto Select)'. Hope this helps.
    I assume that this example was initially created for the Arm Compiler 5. There are several things to consider when such a project is converted to the Arm Compiler 6.
