During porting of some code from i.MX1164 to i.MXRT1176, I have stumbled on a problem I could use some help on....
The (reduced) project implement USB (Bulk, not important). When I enable a specific piece of code, I get the L6244E error, the code:
/* EHCI device driver interface */ static const usb_device_controller_interface_struct_t s_UsbDeviceEhciInterface = { USB_DeviceEhciInit, USB_DeviceEhciDeinit, USB_DeviceEhciSend, USB_DeviceEhciRecv, USB_DeviceEhciCancel, USB_DeviceEhciControl};
The linker file:
#if (defined(__ram_vector_table__)) #define __ram_vector_table_size__ 0x00000400 #else #define __ram_vector_table_size__ 0x00000000 #endif #define m_flash_config_start 0x30000400 #define m_flash_config_size 0x00000C00 #define m_ivt_start 0x30001000 #define m_ivt_size 0x00001000 #define m_interrupts_start 0x30002000 #define m_interrupts_size 0x00000400 #define m_text_start 0x30002400 #define m_text_size 0x00FBDC00 #define m_qacode_start 0x00000000 #define m_qacode_size 0x00040000 #define m_interrupts_ram_start 0x20000000 #define m_interrupts_ram_size __ram_vector_table_size__ #define m_data_start (m_interrupts_ram_start + m_interrupts_ram_size) #define m_data_size (0x00040000 - m_interrupts_ram_size) #if (defined(__use_shmem__)) #define m_rpmsg_sh_mem_start 0x202C0000 #define m_rpmsg_sh_mem_size 0x00002000 #define m_data2_start 0x202C2000 #define m_data2_size 0x0007E000 #else #define m_data2_start 0x202C0000 #define m_data2_size 0x00080000 #endif #define m_core1_image_start 0x30FC0000 #define m_core1_image_size 0x00040000 /* Sizes */ #if (defined(__stack_size__)) #define Stack_Size __stack_size__ #else #define Stack_Size 0x2000 #endif #if (defined(__heap_size__)) #define Heap_Size __heap_size__ #else #define Heap_Size 0x2000 #endif #if defined(XIP_BOOT_HEADER_ENABLE) && (XIP_BOOT_HEADER_ENABLE == 1) LR_m_text m_flash_config_start m_text_start+m_text_size-m_flash_config_start { ; load region size_region RW_m_config_text m_flash_config_start FIXED m_flash_config_size { ; load address = execution address * (.boot_hdr.conf, +FIRST) } RW_m_ivt_text m_ivt_start FIXED m_ivt_size { ; load address = execution address * (.boot_hdr.ivt, +FIRST) * (.boot_hdr.boot_data) * (.boot_hdr.dcd_data) } #else LR_m_text m_interrupts_start m_text_start+m_text_size-m_interrupts_start { ; load region size_region #endif VECTOR_ROM m_interrupts_start FIXED m_interrupts_size { ; load address = execution address * (.isr_vector,+FIRST) } ER_m_text m_text_start FIXED m_text_size { ; load address = execution address * (InRoot$$Sections) .ANY (+RO) } #if (defined(__ram_vector_table__)) VECTOR_RAM m_interrupts_ram_start EMPTY m_interrupts_ram_size { } #else VECTOR_RAM m_interrupts_start EMPTY 0 { } #endif RW_m_data m_data_start m_data_size-Stack_Size-Heap_Size { ; RW data .ANY (+RW +ZI) * (RamFunction) * (NonCacheable.init) * (*NonCacheable) } ARM_LIB_HEAP +0 EMPTY Heap_Size { ; Heap region growing up } ARM_LIB_STACK m_data_start+m_data_size EMPTY -Stack_Size { ; Stack region growing down } #if (defined(__use_shmem__)) RW_m_ncache m_rpmsg_sh_mem_start EMPTY 0 { } RPMSG_SH_MEM m_rpmsg_sh_mem_start UNINIT m_rpmsg_sh_mem_size { ; Shared memory used by RPMSG * (rpmsg_sh_mem_section) } RW_m_ncache_unused m_rpmsg_sh_mem_start+m_rpmsg_sh_mem_size EMPTY 0 { ; Empty region added for MPU configuration } #else RW_m_ram_text m_qacode_start m_qacode_size { ; * (CodeQuickAccess) } RW_m_ncache m_data2_start EMPTY 0 { } RW_m_ncache_unused +0 EMPTY m_data2_size-ImageLength(RW_m_ncache) { ; Empty region added for MPU configuration } #endif } LR_CORE1_IMAGE m_core1_image_start { CORE1_REGION m_core1_image_start m_core1_image_size { *(*core1_code) } }
The specific error from the linker:
flexspi_nor_debug\Application.out: Error: L6244E: Load region LR_m_text address (0x30000400) not aligned on a 2048 byte boundary.
If I specifically change
to
#define m_flash_config_start 0x30000800
The error goes away, but the code will (obviously) not work as the address is wrong.
What am I missing in this ???
The error is likely caused by this default option:https://developer.arm.com/documentation/101754/0620/armlink-Reference/armlink-Command-line-Options/--legacyalign----no-legacyalign
I believe (not tested) that changing the scatter file (line 56 above) to:
LR_m_text m_flash_config_start ALIGN 0x400 m_text_start+m_text_size-m_flash_config_start { ; load region size_region
or
LR_m_text m_flash_config_start AlignExpr(+0, 0x400) m_text_start+m_text_size-m_flash_config_start { ; load region size_region
Regards, Ronan
Thanks Ronan,
unfortunately the "ALIGN 0x400" does not fix it, still reports the error. The "AlignExpr..." gives me syntax error.I got it to run by using --legacyalign, but as you say, this is deprecated and not futureproof....
