Hi,MDK MDK-Plus 7.18.0 over RTX5, compiled with ARM Compiler 6 in uVision 5
I'm using BSD API in non-blocking mode.
This is a complex project (Mongoose, https://mongoose.ws) but basically the problem is with a TCP server,
Open socket, listen, clients connect, accept, configure socket, read/write, and suddenly one of the sockets starts returning BSD_ESOCK to recv() until it is closed.
I have 10 TCP sockets, 10 BSD sockets, 1 listener, and I call `listen()` with a backlog of 5. I don't have more than 3 simultaneous connections, this mostly happens with the second socket after the third connection
Error checking removed for clarity (but done), these are the calls to MDK-Plus, is there anything wrong with this ?
fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP); bind(fd, &sa, slen); listen(fd, 5); setlocaddr(fd, loc); unsigned long on = 1; ioctlsocket(fd, FIONBIO, &on); rc = select((int) maxfd + 1, &rset, &wset, &eset, 1 second)) < 0) do { clear sa fd = accept(fd, &sa, &sa_len); } while (fd == BSD_EWOULDBLOCK) int on = 1; setsockopt(fd, IPPROTO_TCP, TCP_NODELAY, (char *) &on, sizeof(on)) setsockopt(fd, SOL_SOCKET, SO_KEEPALIVE, (char *) &on, sizeof(on)) n = recv(fd, buf, len, MSG_NONBLOCKING); n = send(fd, buf, len, MSG_NONBLOCKING);
