UNINIT Section Gets Zero Filled
I'm trying to declare a variable that can survive a watchdog reset.
I'm using Keil uVision with the MDK-ARM compiler V6.19 with an STM32L0xx microcontroller.
There's a NoInit section of the RAM set up in the project variant options:
I've set the options on the file that has the variable definition to use the NoInit RAM section:
The scatter file for the project is changed to add a .bbs.NoInit section for IRAM2:
; * Scatter-Loading Description File generated by uVision *
LR_IROM1 0x08000000 0x00007FF0 { ; load region size_region
    ER_IROM1 0x08000000 0x00007FF0 { ; load address = execution address
        *.o (RESET, +First)
        *(InRoot$$Sections)
        .ANY (+RO)
        .ANY (+XO)
    RW_IRAM1 0x20000000 0x00001FF0 { ; RW data
        .ANY (+RW +ZI)
    RW_IRAM2 0x20001FF0 UNINIT 0x00000010 { ; No init section
        *(.bss.NoInit)
And the variable is declared like:
   uint8_t  infLoopIdentifier __attribute__((section(".bss.NoInit")));
But the variable is always initialised as 0 after the WDG reset.
I've checked the map file and the variable is being put into the NoInit section:
     infLoopIdentifier                        0x20001ff0   Data           1  lto-llvm-7a9e85.o(.bss.NoInit)
Can anyone help and point out what I'm doing wrong?
Stu
  • Hi Stu,
    I don't see anything obviously wrong in what you are doing. I cannot replicate the issue with a simple example.
    You say that it is initialized after the watchdog reset... is that doing something? Have you tried putting a watchpoint on the address to see if anything else is writing to it? It may also help to declare it as volatile?
    I also note that you have link time optimization enabled. I wonder if that is the source of the issue? If you disable that (in the C/C++ Options pane) does the issue still arise?
    Hope some of these help, Ronan
  • HI Ronan,
    Brilliant, your suggestions helped to fix it. I hadn't thought to use the debugger as the code was running in low power mode and I didn't think it would work correctly.
    It was my own fault. haha. A seemingly innocent function call prior to checking the variable actually called another function and deep in there was a line which set the variable to 0. A few lines of code and everything now works perfectly.
    I have also turned link-time optimization off (not sure why it was on, some default thing? it wasn't in the older V5 compiler as far as I can see.)
    And I re-added the volatile qualifier that I'd taken out previously.
    Many, many thanks for your suggestions, you've saved me a ton of time trying to figure it out.
    Stu
  • Happy to help. Glad to hear you are working again.
    If LTO isn't the cause of the issue, it might be sensible to re-enable it if performance becomes an issue.
    Basically it groups all objects into one big object, and so allows for additional cross-object optimization.
    Regards, Ronan
  • HI Ronan,
    I've re-enabled the LTO and it's still working perfectly.
    Stu
