Send a message to a telnet client without having receive a command first
The callback function netTELNETs_ProcessCommand processes and executes the command requested by the Telnet client.
In my application, I have to send a list of message to answer to only one command request.
I've seen in  the documentation that the function netTELNETs_RequestMessage is used to pass unsolicited messages to the Telnet server.
Is it possible to use this function to send several messages, and how can I use it ?
Thanks !
Thierry
  • It is possible to respond with a larger message, that does not fit into one response packet. The return value of the function netTELNETs_ProcessMessage informs the telnet server that the response is larger and needs more packets to send. The fourth parameter pvar can be used as a helper to process a large response message.
    uint32_t netTELNETs_ProcessCommand (const char *cmd, char *buf, uint32_t buf_len, uint32_t *pvar) {
      uint32_t len = 0;
      if (*pvar == 0) {
        // First call to this function, process command cmd
        // len = Copy initial part of the response into the buf
        // *pvar = 1;
        // Set request for another callback
        return (len | (1u << 31));
      } else {
        // A subsequent call to this function
        // len = Copy message fragment into the buf
        // *pvar++;
        if (!message_done) {
        // This is the last fragment of the message
        return (len);
  • Hello,
    Thanks for your answer.
    I will try if I can send multiple buffers in my application
    Thierry
