Error occured during migration from keil 4 to keil 5.
As the above window shows that MK60F12.h file not found error. Currently I am working this project in keil 5 , as it was build on keil4 previously. In keil 4 its doesn't show the error of MK60F12.h file not found, but shows when migrated to keil 5. Any reason for this error? Note: I am working on MK10FN1M0xxx12 board , so should I compulsorily add the MK60F12.h file. If that file should be added , where can I find or download that file(will it available in .c format or .h format)?
2nd error :
any suggestions regarding the 2 nd error.
Thank You
0
