We are trying to flash and debug on V2M-MPS3 platform (Cortex-M55 core) using Keil MDK with Ulink Pro device.
We are facing error while doing so: “JTAG communication failure”and,“Flash Download failed- Target DLL has been cancelled”
The device gets listed as “Keil ULINKPro” in device manager.
We tried manually loading the .axf file and enabling it through images.txt. However, we’re not sure if this is the correct way to flash and run.
Please find the attached screenshots for reference.
Has anyone faced a similar issue ?Thanks in advance!
In case this is not your current project loaded - do you face the same problem with the corresponding Blinky example offered by the Pack Installer of Keil MDK?
