Hi All,
I am porting the project from CMSIS RTOS1 to RTOS2.
I am little confused on assigning the static memory for RTOS2 queue.
Below is the RTOS1 Method:
m_Keil_Msg_Def.pool = &m_Keil_Msg[i][0]; (uint32_t m_Keil_Msg [50] [4400]) from this pool one of the block is assigned m_Keil_Msg_Def.queue_sz = m_Number_Of_Packets + 4; (m_Number_Of_Packets+4 will be less than or equal to 4400) m_Keil_Msg_ID = osMessageCreate(&m_Keil_Msg_Def, NULL);
Now how can I convert it to RTOS 2
I tried below one but it failed :
m_Keil_Msg_Attr.mq_mem = &m_Keil_Msg[i][0]; m_Keil_Msg_Attr.mq_size = (m_Number_Of_Packets + 4) * sizeof(uint32_t); m_Keil_Msg_ID = osMessageQueueNew (m_Number_Of_Packets + 4 , sizeof(uint32_t), &m_Keil_Msg_Attr);
