I am writing a code to receive the UART protocol transmitted from the motor controller and I am decoding the accepted protocol as speed, voltage and error using arrays. The received protocol is in continuous mode so, I captured them in another buffer to keep them constant. When I am receiving an error, suppose when error = 11, I am getting 10 or 00 like that. How to get the correct value. Here are some references.
Help me in completing this.
This is the code I wrote.
/* USER CODE BEGIN Header */ /** ****************************************************************************** * @file : main.c * @brief : Main program body ****************************************************************************** * @attention * * Copyright (c) 2022 STMicroelectronics. * All rights reserved. * * This software is licensed under terms that can be found in the LICENSE file * in the root directory of this software component. * If no LICENSE file comes with this software, it is provided AS-IS. * ****************************************************************************** */ /* USER CODE END Header */ /* Includes ------------------------------------------------------------------*/ #include "main.h" /* Private includes ----------------------------------------------------------*/ /* USER CODE BEGIN Includes */ #include "string.h" /* USER CODE END Includes */ /* Private typedef -----------------------------------------------------------*/ /* USER CODE BEGIN PTD */ /* USER CODE END PTD */ /* Private define ------------------------------------------------------------*/ /* USER CODE BEGIN PD */ /* USER CODE END PD */ /* Private macro -------------------------------------------------------------*/ /* USER CODE BEGIN PM */ /* USER CODE END PM */ /* Private variables ---------------------------------------------------------*/ UART_HandleTypeDef huart1; DMA_HandleTypeDef hdma_usart1_rx; /* USER CODE BEGIN PV */ /* USER CODE END PV */ /* Private function prototypes -----------------------------------------------*/ void SystemClock_Config(void); static void MX_GPIO_Init(void); static void MX_DMA_Init(void); static void MX_USART1_UART_Init(void); void Ringbuf_Init(void); void Ringbuf_Reset(void); void lcd_data(char data,int rs); void lcd_send_cmd (char cmd); void lcd_send_data (char data); void lcd_init (void); void lcd_display(unsigned char *s); /* USER CODE BEGIN PFP */ /* USER CODE END PFP */ /* Private user code ---------------------------------------------------------*/ /* USER CODE BEGIN 0 */ #define RxBuf_Size 20 #define MainBuf_Size 14 uint8_t RxData[RxBuf_Size]; uint8_t MainData[MainBuf_Size]; uint16_t oldPos = 0; uint16_t newPos = 0; uint16_t Head, Tail; int call=0; int errorcall=0; int a,b,c; int i,j,k,l,m,n,o,p; int x,y; int Error,Speed; int Key1 = 'A', Key2 = 'B', Key3 = 'C'; int flag1 = 0, flag2 = 0, flag3 = 0; float Voltage; float nearest,ans,q; char buffer[14]; void seperation(uint8_t arr[]) { //Decoding the speed value a = arr[2] - '0'; b = arr[3] - '0'; c = arr[4] - '0'; Speed = 100.0*a + 10.0*b + c; //Decoding the voltage value k = arr[6] - '0'; l = arr[7] - '0'; m = arr[9] - '0'; n = arr[10] - '0'; p = 10.0*k + l; q = (10.0*m + n)/100.0; ans = p + q; Voltage= (long int) ((ans)*100+0.5) / 100.0; //Decoding the Error value if(arr[12]==0x00 && arr[13]==0x00) { Error=0; } else { x = arr[12] - '0'; y = arr[13] - '0'; Error = 10.0*x + y; } } void HAL_UART_ErrorCallback(UART_HandleTypeDef *huart) { NVIC_SystemReset(); HAL_UART_DeInit(&huart1); HAL_UARTEx_ReceiveToIdle_DMA(&huart1, (uint8_t *) RxData, RxBuf_Size); __HAL_DMA_DISABLE_IT(&hdma_usart1_rx, DMA_IT_HT); } //UART Reception Callback void HAL_UARTEx_RxEventCallback(UART_HandleTypeDef *huart, uint16_t Size) { if (huart->Instance == USART1) { HAL_UARTEx_ReceiveToIdle_DMA(&huart1, (uint8_t *) RxData, RxBuf_Size); __HAL_DMA_DISABLE_IT(&hdma_usart1_rx, DMA_IT_HT); //memcpy (MainData, RxData, Size); seperation(MainData); for (i=0; i<Size; i++) { if ((RxData[i] == Key1) && (RxData[i+1] == Key1) &&(RxData[i+6] == Key2) && (RxData[i+12] == Key3)) { MainData[0] = RxData[i]; MainData[1] = RxData[i+1]; MainData[2] = RxData[i+2]; MainData[3] = RxData[i+3]; MainData[4] = RxData[i+4]; MainData[5] = RxData[i+6]; MainData[6] = RxData[i+7]; MainData[7] = RxData[i+8]; MainData[8] = RxData[i+9]; MainData[9] = RxData[i+10]; MainData[10] = RxData[i+11]; MainData[11] = RxData[i+12]; MainData[12] = RxData[i+13]; MainData[13] = RxData[i+14]; break; } } } else { Voltage=0; } } /* USER CODE END 0 */ /** * @brief The application entry point. * @retval int */ void lcd_data(char data,int rs) { HAL_GPIO_WritePin(GPIOA,GPIO_PIN_1,rs); HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, ((data>>3)&0x01)); HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, ((data>>2)&0x01)); HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, ((data>>1)&0x01)); HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, ((data>>0)&0x01)); HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,1); HAL_Delay(5); HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,0); HAL_Delay(5); } void lcd_send_cmd (char cmd) { char datatosend; datatosend = ((cmd>>4)&0x0f); lcd_data(datatosend,0); datatosend = ((cmd)&0x0f); lcd_data(datatosend, 0); } void lcd_send_data (char data) { char datatosend; datatosend = ((data>>4)&0x0f); lcd_data(datatosend, 1); datatosend = ((data)&0x0f); lcd_data(datatosend, 1); } void lcd_init (void) { HAL_Delay(500); lcd_send_cmd(0x02); // Return Home lcd_send_cmd(0x28); //4 bit mode lcd_send_cmd(0x0C); //Display on/cursor off lcd_send_cmd(0x01); // clear display HAL_Delay(10); } int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration--------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* USER CODE BEGIN Init */ /* USER CODE END Init */ /* Configure the system clock */ SystemClock_Config(); /* USER CODE BEGIN SysInit */ /* USER CODE END SysInit */ /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_DMA_Init(); MX_USART1_UART_Init(); /* USER CODE BEGIN 2 */ HAL_UARTEx_ReceiveToIdle_DMA(&huart1, RxData, RxBuf_Size); __HAL_DMA_DISABLE_IT(&hdma_usart1_rx, DMA_IT_HT); /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ int voltagenew; int speed1; int error1,voltage1,error2; lcd_init(); while (1) { if(MainData[4]>47 && MainData[4]<58) { if(MainData[3]>47 && MainData[3]<58) { if(MainData[2]>47 && MainData[2]<58) { if(MainData[6]>47 && MainData[6]<58) { if(MainData[7]>47 && MainData[7]<58) { if(MainData[9]>47 && MainData[9]<58) { if(MainData[10]>47 && MainData[10]<58) { if(MainData[2]>47 && MainData[2]<58) { if(MainData[3]>47 && MainData[3]<58) { if(MainData[0]>64 && MainData[13]<91) { if(MainData[1]>64 && MainData[13]<91) { if(MainData[5]>64 && MainData[5]<91) { if(MainData[11]>64 && MainData[11]<91) { seperation(MainData); voltagenew=Voltage*100; speed1=Speed*1; error1=Error*1; lcd_send_cmd(0x80); lcd_display("SPD:"); lcd_send_cmd(0x84); lcd_send_data((Speed/100)+48); lcd_send_data(((Speed/10)%10)+48); lcd_send_data((Speed%10)+48); lcd_send_cmd(0x89); lcd_display("ERR:"); lcd_send_cmd(0x8D); lcd_send_data((Error/10)+48); lcd_send_data((Error%10)+48); lcd_send_cmd(0xC0); lcd_display("VOLTAGE:"); lcd_send_cmd(0xC9); lcd_send_data((voltagenew/1000)+48); lcd_send_data(((voltagenew/100)%10)+48); lcd_send_data(0x2E); lcd_send_data(((voltagenew/10)%10)+48); lcd_send_data((voltagenew%10)+48); voltage1=voltagenew; HAL_Delay(10); } } } } } } } } } } } } } else { lcd_send_cmd(0x80); lcd_display("SPD:"); lcd_send_cmd(0x84); lcd_send_data((speed1/100)+48); lcd_send_data(((speed1/10)%10)+48); lcd_send_data((speed1%10)+48); lcd_send_cmd(0x89); lcd_display("ERR:"); lcd_send_cmd(0x8D); lcd_send_data((error1/10)+48); lcd_send_data((error1%10)+48); lcd_send_cmd(0xC0); lcd_display("VOLTAGE:"); lcd_send_cmd(0xC9); lcd_send_data((voltage1/1000)+48); lcd_send_data(((voltage1/100)%10)+48); lcd_send_data(0x2E); lcd_send_data(((voltage1/10)%10)+48); lcd_send_data((voltage1%10)+48); } } /* USER CODE END 3 */ } void lcd_display(unsigned char *s) { while(*s) { lcd_send_data(*s++); HAL_Delay(50); } } /** * @brief System Clock Configuration * @retval None */ void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; /** Initializes the RCC Oscillators according to the specified parameters * in the RCC_OscInitTypeDef structure. */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; RCC_OscInitStruct.HSEState = RCC_HSE_ON; RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1; RCC_OscInitStruct.HSIState = RCC_HSI_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /** Initializes the CPU, AHB and APB buses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) { Error_Handler(); } } /** * @brief USART1 Initialization Function * @param None * @retval None */ static void MX_USART1_UART_Init(void) { /* USER CODE BEGIN USART1_Init 0 */ /* USER CODE END USART1_Init 0 */ /* USER CODE BEGIN USART1_Init 1 */ /* USER CODE END USART1_Init 1 */ huart1.Instance = USART1; huart1.Init.BaudRate = 9600; huart1.Init.WordLength = UART_WORDLENGTH_8B; huart1.Init.StopBits = UART_STOPBITS_1; huart1.Init.Parity = UART_PARITY_NONE; huart1.Init.Mode = UART_MODE_TX_RX; huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart1.Init.OverSampling = UART_OVERSAMPLING_16; if (HAL_UART_Init(&huart1) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN USART1_Init 2 */ /* USER CODE END USART1_Init 2 */ } /** * Enable DMA controller clock */ static void MX_DMA_Init(void) { /* DMA controller clock enable */ __HAL_RCC_DMA1_CLK_ENABLE(); /* DMA interrupt init */ /* DMA1_Channel5_IRQn interrupt configuration */ HAL_NVIC_SetPriority(DMA1_Channel5_IRQn, 0, 0); HAL_NVIC_EnableIRQ(DMA1_Channel5_IRQn); } /** * @brief GPIO Initialization Function * @param None * @retval None */ static void MX_GPIO_Init(void) { GPIO_InitTypeDef GPIO_InitStruct = {0}; /* GPIO Ports Clock Enable */ __HAL_RCC_GPIOD_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); /*Configure GPIO pin Output Level */ HAL_GPIO_WritePin(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3 |GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7, GPIO_PIN_RESET); /*Configure GPIO pins : PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 */ GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3 |GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); } /* USER CODE BEGIN 4 */ /* USER CODE END 4 */ /** * @brief This function is executed in case of error occurrence. * @retval None */ void Error_Handler(void) { /* USER CODE BEGIN Error_Handler_Debug */ /* User can add his own implementation to report the HAL error return state */ __disable_irq(); while (1) { } /* USER CODE END Error_Handler_Debug */ } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t *file, uint32_t line) { /* USER CODE BEGIN 6 */ /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* USER CODE END 6 */ } #endif /* USE_FULL_ASSERT */
