I'm working on a project and now I need to create a new project that will use some files from that project.
Is there an option to convert project file to a workspace file or do I need to create a multi project workspace and add the projects I want?
Thanks.
The recommended solution is, as you may expect, the creation and management of a Multi-Project Workspace:
https://developer.arm.com/documentation/101407/0537/Creating-Applications/Multi-Projects
Dumb followup question from the peanut gallery, ... you can't accomplish what you want to do by adding a new Target under the existing Project?
Target used for both projects is the same. I want to have 2 apps that uses some shared files and libraries
Right, this is introduced at i.e.:
https://developer.arm.com/documentation/101407/0537/Creating-Applications/Project-Targets-and-File-Groups
