I am using LPC43S57 controller.
The program size is 335K bytes. Flash bank A size is 512kB and around 200kB is used by the bootloader and remaining 312kB is not enough for the program.
There is Flash bank B with size of 512kB. But when I configure the scatter file to use the Flash bank B the program doesn't executes.
Below I have attached the scatter file configuration.
; ************************************************************* ; *** Scatter-Loading Description File generated by uVision *** ; ************************************************************* LR_IROM1 0x1A030000 0x00050000 ; load region size of region { ER_IROM1 0x1A030000 0x00050000 ; execution address and size Flash Bank A { *(InRoot$$Sections) *.o (RESET, +First) *(.init_array) .ANY (+RO) } RW_IRAM1 0x10000000 0x00008000 ; RW data bytes 32KB Local SRAM { .ANY (+RW +ZI) } RW_IRAM2 0x10080000 0x00009FE0 ; RW data bytes 32KB + 8KB -32Bytes Local SRAM { *(STACK) } RW_IRAM3 0x10089FE0 FILL 0xAAAAAAAA 0x00000020 ; RW data This section 32Bytes is reserved for IAP { } RW_IRAM4 0x20000000 0x00010000 ; RW data bytes 4 x 16 kB AHB SRAM { .ANY (+RW +ZI) } RW_RAM1 0x28000000 0x800000 ; RW data, slower performing SDRAM 8MB { *(HEAP) .ANY (+RW +ZI) } } LR_IROM2 0x1B010000 0x00040000 { ER_IROM2 0x1B010000 0x00040000 ; execution address and size Flash Bank A { .ANY (+RO) } }
If anyone has the solution or example code to use both the Flash bank A and B, Kindly share it with me.
I see no general issue with the scatter file so far. So can you please describe "program doesn't executes" in more detail?
Apart from that, there is the following article:
https://developer.arm.com/documentation/ka002219/latest
that covers a few common issues like that. So please also have a look there to check if one of these applies to your issue.
Hello Barth,
Thanks for responding.
What I meant by "program doesn't executes" is that the Program doesn't reach main function when I define the LR_IROM2 section in the scatter file.
If the LR_IROM2 section is removed from scatter file then the Program works fine.
Then please check
does something apply?
No Barth.
I have kept the heap size to 500kB and Semi hosting is not enabled. Reset line also doesn't has any issues.
The same program works fine if the LR_IROM2 section is not present in scatter file.
When you stop program execution when the program does not reach main(), where is the PC located then when the execution is halted?
Then execution is halted at "0x1A076654 E7FE B 0x1A076654"
That is an endless loop that the program might reached due to some error condition. However, it is a bit strange, that all registers read 0. Does the Call Stack window give any information? And please also share the mapfile of this build so that we might can find out what is there.
Please refer this screenshot.
Still no Call Stack Window visible and no mapfile provided.
Thank you for the support. The above issue is resolved.In the bootloader the reserved memory area was not taken into consideration, Hence it was trying to access the reserved memory.
