is it possible to add a newer armcompiler >=6.16 from the arm website to MDK 5.26?
when I try to add the arm compiler 6.18 I get the error: "unsupported Compiler - Version 5 or newer required"
Thank you in advance
if your MDK license hasn't expired, you can follow this page to add a new compiler toolchain (no matter if it is arm compiler v5.x or 6.x) into your MDK installation:
developer.arm.com/.../
On other hand, MDK only supports 32-bit version of our arm compiler toolchain. Make sure you have downloaded the 32bit version
This is what I did, with Arm Compiler for Embedded 6.18 (for Keil ®️ MDK) which is x86_32 from developer.arm.com/.../arm-compiler-for-embedded
however when I tried to add the compiler to the MDK I got the error message stated above
